RV.Net Open Roads Forum: Beginning RVing: Splendid Washer/Dryer
 > Splendid Washer/Dryer
Allworth
Orlando, FL
Posted: 09/25/19 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
What are these things you call "pressed and starched shirts"???
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
2oldman
New Mexico
Posted: 09/25/19 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
Planning
Idaho
Posted: 10/03/19 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
Also, do not neglect manually initiating a lint-cleaning procedure (as recommended by Splendide) to prevent the dryer air duct from clogging:
Obtained in 2011 from Splendide’s Technical operation, Westland Sales in Oregon 800-356-0766 (#5), or 503-656-2280 (#5) technician San Saechao
PROCEDURE FOR CLEARING LINT FROM MACHINE’S INTERIOR DUCT
1. Run the unit, without clothes, and with the dry time off, on cycle #11.
2. When the water stops entering the unit push, and hold the start
button until all the lights come on, then release the button.
3. Next, move the cycle knob to cycle # 2 and press the start button
once (do not hold). The unit will resume filling with additional water.
4. Let it run through that complete cycle.
5. Do this twice.
If in frequent use, do this once each month to avoid buildup.
If the above treatment fails, try it again, adding a cup of white vinegar to break down the deposited soap and fabric softener.
FALL BACK PROCEDURE IF THE ABOVE PROCEDURE FAILS
1. Pull the unit out and remove flexible exhaust duct.
2. Pick out as much lint as you can from the air outlet on the back of
the dryer.
3. Put a garden hose in the outlet and blow the blockage into the
washer.
4. Run the washer on a short cycle. The blockage breaks up and
goes out the drain.
2016 AF 29-5K; 2016 F350 6.7, 4x4, CCLB DRW
