RV.Net Open Roads Forum: General RVing Issues: Campground washroom needs GFCI
 > Campground washroom needs GFCI
Yeti plus
S.W. Ontario
Posted: 09/25/19 07:29pm Link  |  Print  |  Notify Moderator
Testing is easy . I carry a GFCI tester with me. It looks like a receptacle tester with a test button on top. Plug it in, tells if receptacle is wired properly, push the button and it trips GFCI.
">AIaIQobChMI-7Cgx6rt5AIVERgMCh0aygAvEAQ........ASABEgIG2PD_BwE,gclsrc:aw.ds]GFCI tester
I should add, if the receptacle is protected by another device, the problem then arises to find the device, either breaker or upstream receptacle.
Brian
2014 Chevrolet 3500 CC 4X4 Duramax, Tork Lift Tiedowns, TorkLift Fastguns, Superhitch and supertruss
2009 Jayco 213
2008 Bigfoot 25C9.4
Cummins12V98
on the road
Posted: 09/25/19 07:42pm Link  |  Print  |  Notify Moderator
Older facility? If so it was not required at the time. Local codes may not require updating.
Could be a GFCI breaker.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ScottG
Bothell Wa.
Posted: 09/25/19 07:46pm Link  |  Print  |  Notify Moderator
It has to be protected since it's a commercial or public facility (goes for rentals too).
No grandfathering.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
cavie
Posted: 09/25/19 08:02pm Link  |  Print  |  Notify Moderator
Artum Snowbird wrote:
Well, the question came up. Testing to see if it is GFCI protected. That is what the OP asked about, so how does one safely test it?
Plug in gfi circuit tester. 3 lights and a push button.
cavie
Posted: 09/25/19 08:05pm Link  |  Print  |  Notify Moderator
No grandfathering.
If it passed inspection before the GFI requirement the is no code to make them upgrade to GFI. Yes it can be grandfathered.
camperdave
northern, California
Posted: 09/25/19 08:16pm Link  |  Print  |  Notify Moderator
Excuse me sir, but the power seems to be out in the bathroom. [emoticon]
ScottG
Bothell Wa.
Posted: 09/25/19 08:18pm Link  |  Print  |  Notify Moderator
cavie wrote:
No grandfathering.
Per NEC, NOT in a commercial, public or rental property. I have been though this many times and I am 100% sure of this.
Now if some local yocals don't adopt NEC requirements then anything goes but the code is clear.
Old-Biscuit
Verde Valley
Posted: 09/25/19 09:35pm Link  |  Print  |  Notify Moderator
Probably got rid of the GFI ...too many complaints of it tripping when using electric shavers, hair dryers, coffee pots, curling irons and instant pots.
Folks will plug just about anything into any outlet......
larry cad
ohio
Posted: 09/26/19 01:29am Link  |  Print  |  Notify Moderator
ScottG wrote:
cavie wrote:
No grandfathering.
Can you point out the specific section of the NEC where it states that new sections of the code must be enforced on previously legal wiring? I personally have never run across that section. I realize you are 100% sure but I need to reference a NEC section and can't find it.
Our Travel Blog
edbehnke
North America (from Michigan)
Posted: 09/26/19 04:52am Link  |  Print  |  Notify Moderator
grit dog....i like it.
eddie and sandie
3402 Montana 2013
Ford F350 2015
