RV.Net Open Roads Forum: Tech Issues: Dometic - Up or Down
 > Dometic - Up or Down
bobcouch
Southeast Texas
Posted: 09/26/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Actually two questions...
We got flooded out of our house by Imelda, and will be living in our 5th wheel for the foreseeable future.
We have a brand new Dometic fridge that is running almost cool enough on max setting. I know moving the slide up or down the fins changes the temp, but I can't remember which way is which.
question 2 - I know it cools faster on propane, but should it maintain the temp I want on AC? Outside temps 80s to low 90s.
Bob and Honey Couch
2008 Keystone Everest
2007 Dodge MegaCab w/ 5.9 Cummins
http://boggythicket.blogspot.com/
agesilaus
North Florida
Posted: 09/26/19 10:04am Link  |  Quote  |  Print  |  Notify Moderator
You talking about your refrigerator or the a/c : air conditioner? I have yet to hear of running the a/c on propane. I understand that if you put a sun blocking shield over the side of the RV where the fridge vents that will help. Reflextrix should work well and you can get that at Lowes or Home Depot. Some people install a fan inside the fridge and/or behind it.
For the a/c pull the cover off and clean the coils. Clean the filter inside.
Generally most people think that the fridge cools down faster on electricity.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
DutchmenSport
Indiana
Posted: 09/26/19 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Down = colder. Yes, should maintain on electric. Electric should take it down and hold it too.
Although we no longer have a gas-electric refer, on all my 3 past TT's, electric always brought the freezer to -2 and the refer to about 36-38 when outside temps were in the 80's and 90's. I moved the temperature slide all the way to be bottom, as far as it would reach and just left it there. Never had a problem, and any time of year, under any conditions, the freezer was always -2.
lap527
Ocala, Florida
Posted: 09/26/19 11:06am Link  |  Quote  |  Print  |  Notify Moderator
hmmm.....we were always told that sliding it up meant colder. Inquiring minds sure would like to know. Would it matter what kind of rv refrigerator it is?
2006 Dodge 3500 dually 4X4 / 2013 Livin Lite 10.0 TC /Torklift talons, fastguns, stableloads, superhitch, and truss/ towing a
14'V Nose Trailer Hauling 2014 Tri-glide Harley Davidson, recently added a 2016 Livin Lite 21RBS travel trailer. No Wood!No Rot!
DutchmenSport
Indiana
Posted: 09/26/19 11:28am Link  |  Quote  |  Print  |  Notify Moderator
OK, you are correct. I looked up a couple YouTube videos and "UP" is colder. Sorry, my bad.
I guess I had the wire stretched to the max with the slide going up.
2oldman
AZ
Posted: 09/26/19 11:30am Link  |  Quote  |  Print  |  Notify Moderator
A new fridge should have the proper fin setting printed on the wall next to it.
Nutinelse2do
On the Road Where the Weather Suits Our Clothes
Posted: 09/26/19 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Up is colder, down warmer
Get a snip the tip, and then you don’t have to worry about moving it
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
lap527
Ocala, Florida
Whew....thanks for the correction...makes me feel better about our fridge.
Nutinelse2do
Posted: 09/26/19 11:36am Link  |  Quote  |  Print  |  Notify Moderator
My experience is Dometic fridges do better at 7-8, instead of max.
Try going down a bump with the outside setting, wait 24 hours, then readjust as needed with the thermostat inside
Yes, it should maintain temp on electric.
Old-Biscuit
Verde Valley
Posted: 09/26/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Moving the thermistor can affect the overall fridge temps by 4*F-6*F on the Models that have 'AUTO TEMP CONTROLS' (NO temp adjustment settings)
UP on the Fin....COLDER
DOWN on the Fin..WARMER
Models WITH Temp Setting controls (1-5 & 1-9) should have the thermistor left in the OEM position (mid FIN on fin specified by RV MFG.----far right/far left/10th fin etc)
Fridge Thermostat is factory calibrated to control temp based on feed back from thermistor on specific position on fin
Propane will START the cooling process quicker then Electric due to the initial heat transfer by the hot flame
Electric and propane are sized to produce roughly the SAME heat required to boil the ammonia into a sufficient quanity of vapor for the cooling process
