RV.Net Open Roads Forum: Tech Issues: The kid meets the furnace thermostat...
 > The kid meets the furnace thermostat...
groundhogy
PA
Posted: 09/27/19 06:07am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
So she’s been back there before...
Likes to pull the cover off the thermostat.
This time, she pulled the thermal expansion spring out.
(She did this just as i was finishing fixing the last thing she messed up. Lol)
Anyway, my questions..
Current thermostat is a mechanical Suburban. Has on/off switch and temperature setting. I haven’t yet pulled it off, so I don’t know how many wires are serving the thermostat. All i know is that there are two that go short/open for heat or no heat.
What are my replacement options?
Do i have to stick with the RV mechanical units or do i have the option of going to a digital unit?
Thanks in advance of your help.
groundhogy
dougrainer
Carrolton, Texas
Posted: 09/27/19 06:14am Link  |  Quote  |  Print  |  Notify Moderator
The mechanical just has the 2 wires. All the Tstat does is connect(close) the 2 wires to make a circuit back to the furnace. So, just replace with another Mechanical. Digital units will require extra wiring you will not have at the existing tstat. Doug
SoundGuy
S Ontario
Posted: 09/27/19 06:39am Link  |  Quote  |  Print  |  Notify Moderator
Hate to disagree with you Doug but I installed a simple digital thermostat in my 2003 Yuma. It's self powered with an internal battery and all that connected to it were the 2 wires that were wired to the original bi-metal thermostat.
I also used that very same thermostat in our TrailCruiser hybrid.
In both those campers the thermostat controlled just the furnace but in our KZ Spree which had ducted A/C the thermo controlled both the furnace and the A/C but I used the same wires that were wired to the original thermostat.
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
rrupert
NW PA
Posted: 09/27/19 07:05am Link  |  Quote  |  Print  |  Notify Moderator
If you have the simple two wire thermostat go to HD or Lowe's and get a simple digital non-programmable thermostat. It's a very easy hookup and it will give more accurate temperature control. You will thank your daughter for pulling the old one apart.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
Dusty R
Charlotte Michigan 48813
Posted: 09/27/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
If you do decide to go with an electronic one, it must be powered with it's own battery. RV heating units run on 12 DC and home one use 24v AC for control power.
Dusty
groundhogy
PA
Posted: 09/27/19 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Yes, im looking at this one...
https://www.supplyhouse.com/Lux-PSD010B-LuxPro-Digital-2-Wire-Heat-Only-Thermostat
Im coming across it alot on the web. What do you guys think?
groundhogy
PA
Posted: 09/27/19 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Manual for...
https://www.manualslib.com/manual/763253/Lux-Products-Psd010b.html
time2roll
Posted: 09/27/19 09:02am Link  |  Quote  |  Print  |  Notify Moderator
I have this one in a rental condo works fine. Can't remember if it is battery powered. Generally these home units are designed to switch 24vac but should work fine if battery powered.
675w Solar pictures back up
opnspaces
San Diego Ca
Posted: 09/27/19 09:08am Link  |  Quote  |  Print  |  Notify Moderator
That one will work just fine. I found mine at Walmart for a bit cheaper though it was a few years ago. I think any of the digitals with a battery backup will do what you're looking for. Here's a $22 from Home Depot
Link
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
wnjj
Cornelius, Oregon
Posted: 09/27/19 09:11am Link  |  Quote  |  Print  |  Notify Moderator
groundhogy wrote:
Manual for...
Should work fine. Go for it.
