RV.Net Open Roads Forum: Tech Issues: The kid meets the furnace thermostat...
 > The kid meets the furnace thermostat...
2oldman
Ca
Posted: 09/27/19 09:17am Link  |  Quote  |  Print  |  Notify Moderator
You don't have air?
Boon Docker
Mountain Foothills of South Western Alberta
Posted: 09/27/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
groundhogy wrote:
Yes, im looking at this one...
https://www.supplyhouse.com/Lux-PSD010B-LuxPro-Digital-2-Wire-Heat-Only-Thermostat
Im coming across it alot on the web. What do you guys think?
You can go with a battery operated programmable also if you want to.
Dutch_12078
Winters south, summers north
Posted: 09/27/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Once you get the thermostat replaced, you might want to consider one of these until she's old enough to understand the consequences of her actions.
Locking thermostat covers
Dutch
2001 GBM Landau 34' Class A
groundhogy
PA
Posted: 09/27/19 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
One more question on these digital battery powered units...
Say its deep winter time... your not home (RV home)...
The little AA battery croaks...?
dougrainer
Carrolton, Texas
Posted: 09/27/19 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
SoundGuy wrote:
dougrainer wrote:
The mechanical just has the 2 wires. All the Tstat does is connect(close) the 2 wires to make a circuit back to the furnace. So, just replace with another Mechanical. Digital units will require extra wiring you will not have at the existing tstat. Doug
Hate to disagree with you Doug but I installed a simple digital thermostat in my 2003 Yuma. It's self powered with an internal battery and all that connected to it were the 2 wires that were wired to the original bi-metal thermostat.
I also used that very same thermostat in our TrailCruiser hybrid.
In both those campers the thermostat controlled just the furnace but in our KZ Spree which had ducted A/C the thermo controlled both the furnace and the A/C but I used the same wires that were wired to the original thermostat.
I Know about battery powered. But, not really needed for a basic mechanical wall furnace tstat. As another posted, what happens when the battery goes dead? Doug
2oldman
Ca
groundhogy wrote:
the little AA battery croaks...?
Buy good quality batteries like Duracell. They should last a couple years. If in doubt, check/change them every year.
Bert Ackerman
Palm Beach
Posted: 09/27/19 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
It will stop working. Put a new one in the fall. They typically last a few years before needing changed, and probably will have a low battery indicator regardless.
opnspaces
San Diego Ca
Posted: 09/27/19 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
I think I change my batteries every other year or so. But realize the batteries in the thermostat only power the small circuit board and display on the thermostat and have nothing to do with powering the furnace. So they will easily last a year and probably three years before needing changing. Though if you're concerned you could change the batteries every fall but that is probably a bit excessive.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
time2roll
Posted: 09/27/19 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
I would leave it not working for next trip. A little learning experience on how breaking things has consequences (no heat). Maybe even work with the child to put that spring back in before you whip out the digital. Nothing remotely harsh, just a bit of reality.
675w Solar pictures back up
Wherever I happen to park
Posted: 09/27/19 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
FIrst I like a Spring type T-Stat for the furnace on an RV. With contacts (old days they used mercury tilt switches but todays are Mercury Free)
ACE hardware 20 bucks
Why do I like the mercury free. Well the mercury type need to be perfectly positioned. if your unit is tilted even a little bit it throws it off. But the contact type .. Do not care
Home is where I park it.
