RV.Net Open Roads Forum: Class A Motorhomes: 6" valve stems
 > 6" valve stems
Hoot887
Shelter Island, NY USA
Posted: 09/27/19 08:41am Link  |  Quote  |  Print  |  Notify Moderator
does anyone know where I can get 6" valve stems for the inside duals
thanks,
Hoot
10forty2
North Carolina
Posted: 09/27/19 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Dually Valve Stems
You should be able to find the right ones for your application. Best money I've spent on mine so far!
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
kdk
usa
Posted: 09/27/19 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
If you install these from experience also install rubber wheel inserts to support them
06 Holiday Rambler Ambassador
2015 Wrangler Sahara 4 door
10forty2
North Carolina
Posted: 09/27/19 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Good point! The kit I bought from that link included the rubber stabilizers!
Hoot887
Posted: 10/04/19 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
I went to Dually Valve Stems and they were great.
Thanks a lot
Hoot
Wherever I happen to park
Posted: 10/04/19 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks a lot
Hoot
Same here Very happy way easier to check/add air.
Home is where I park it.
TxGearhead
Posted: 10/12/19 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
Amazon. But you might have to fiddle with them. If they won't take air back the wheel valves out about a quarter turn at a time.
Milton is probably the best quality.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
 > 6" valve stems
