RV.Net Open Roads Forum: Class A Motorhomes: Battery Hold downs
 > Battery Hold downs
RLS7201
Posted: 09/27/19 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
SS hold down brackets
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
DrewE
Vermont
Posted: 09/27/19 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
I use nylon tie-down straps, in combination with some homebuilt painted wooden blocks shaped to guide the straps over the tops of the batteries without fouling the vent caps etc.
It is not a very good idea to omit the hold down, as much to ensure they cannot short out on the vehicle frame in a collision as anything.
garyemunson
Reno, Nevada
Posted: 09/28/19 05:43am Link  |  Quote  |  Print  |  Notify Moderator
If you are talking 6 volt golf cart batteries (my battery of choice), I use these. They go across the long edge on the top of the battery and you use threaded rod at a 45 degree angle to the opposite side base of the battery. This does require having something for the battery to set against on the opposite side bottom. Makes for a solid mount.
https://www.ebay.com/itm/Yamaha-Gas-Golf-Cart-Battery-Hold-Down-Plate-G1-to-G22-1978-UP-New-Parts/121680830113?epid=14024867329&hash=item1c54be1ea1:g:0UwAAOSwNSxVSTiz
Gjac
Milford, CT
Posted: 09/28/19 07:29am Link  |  Quote  |  Print  |  Notify Moderator
I used threaded rod and angle iron to hold my two GC batteries in place. Mine are not on a slide out tray so filling the cells with water is difficult to see so most of the time they were over filled and the angle iron corroded away in about 5 or 6 years. I made new ones from an old bed frame the L section was a little thicker and was painted. I gave it another coat of black paint and they have been on for about 10 years and are still OK.
FIRE UP
Lake Havasu City AZ
Posted: 09/28/19 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Well,
I'll more than likely get a bit of flaming for this but, no biggie, been flamed many, many times both in my career and on here. Anyway, I changed from (3) 12V Junk INTERSTATE batteries to (4) Costco 6V Golf Cart batteries over 7 years ago and, since I have very, very little clearance above the batteries, I have NO HOLD DOWNS at all on those. They weigh 67 lbs EACH!!!!!!!!
Those (4) batteries are very close to each other and have a small spacer in between them so to just keep them from POTENTIALLY from sliding around. Now, am I gonna BOUNCE them out of their somewhat secure position, with any sort of rough road or intersection? Nope, not gonna happen. As stated, they've been that way for almost 8 years and haven't moved one micro inch.
Scott
Scott and Karla
SDFD RETIRED
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
RLS7201
Posted: 09/28/19 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
FIRE UP wrote:
Well,
Scott
Scott, I also have no hold downs on my 4 GC batteries, but if they jiggle loose they have no way out but up 2 1/2 feet and out the hood opening. I have seen some under the stair batteries that have little surrounding them and could escape if not secured. I think it all depends...............
Richard
FIRE UP
Lake Havasu City AZ
Posted: 09/28/19 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
RLS7201 wrote:
FIRE UP wrote:
Well,
Scott
Richard
Hey Richard,
Yeah, if mine had little to no side wall restriction, I'd find some sort of way to tie them down. But, the House battery tray is approximately 4" deep and, those batteries are snug as a bug in a rug in there. I'd have to do a moto cross race with it in order for those four house batts to even think about trying to get out of their enclosure.
Scott
RLS7201
Posted: 09/29/19 11:35am Link  |  Quote  |  Print  |  Notify Moderator
FIRE UP wrote:
RLS7201 wrote:
FIRE UP wrote:
Well,
Scott
Richard
Hey Richard,
Scott
You still have dirt bikes? Ya have an extra? Lets go riding. I just sold my last dirt bike about a month ago. [emoticon] Now I down to Segways for two wheeling.
FIRE UP
Lake Havasu City AZ
Posted: 09/29/19 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
RLS7201 wrote:
FIRE UP wrote:
RLS7201 wrote:
FIRE UP wrote:
Well,
Scott
Richard
Hey Richard,
Scott
Richard,
Well, yeah, in fact I do have a dirt bike, sort-a. It's a Yamaha TW200. It's a combo thing. Don't know if you know about them or not but, if not, they're neat little toy. I'd post a pic but, Rv.net makes it so hard to post a pic, vs say, other RV forums. Look them up, they're a kick in the pants.
Scott
Two Jayhawks
Lenexa Kansas
Posted: 10/01/19 07:45am Link  |  Quote  |  Print  |  Notify Moderator
Can you utilize straps instead of a hold down bracket? Mine are just Husky straps from Home Depot.
Bill & Kelli
2015 DSDP 4366 pulling a 2014 Ford Edge
2002 Safari Zanzibar 3906 gone
1995 Fleetwood Bounder 36JD gone
