RV.Net Open Roads Forum: Tech Issues: First time Eternabond user observations
 > First time Eternabond user observations
MURPHY55347
Savage, MINNESOTA
Posted: 09/27/19 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Wow is this stuff sticky! Once it touches anything it is stuck for good. When doing a long seam make sure you get the tape started straight. When pulling off the backing to expose the adhesive make sure to pull it off straight. I tried pulling it off at an angle and the backing tore at a 45 degree angle so now I had a piece that only half stuck. That was not fun trying to fix. Prepped the area with acetone and that worked well. Using a razor blade to cut the tape works best. Rolled with a plastic wall paper roller and that worked good. I know some people here like to follow up with a dab of Doctor at the edges but I see no reason to.
Wherever I happen to park
Posted: 09/27/19 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Yup. Why it is named "Eternabond" after all [emoticon]
glad you like it.
Home is where I park it.
gbopp
The Keystone State
Posted: 09/27/19 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
I like to use Dicor but, I guess Doctor will work just as well. [emoticon]
It's not necessary but, I think it helps seal the edge of the eternabond. I usually go for the overkill.
MURPHY55347
Savage, MINNESOTA
Posted: 09/27/19 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
Oops. Must be spellchecker at work. Yes I meant Dicor.
West & above Bishop, California
Posted: 09/27/19 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
You can also clean the surface with EternaClean, Lacquer Thinner,Denatured Alcohol, etc.
Halmfamily
Munford, AL
Posted: 09/27/19 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
I Eternabond taped all seams on our roof several years ago and still holding strong.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
beemerphile1
Ohio
Posted: 09/27/19 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
I cut shorter more manageable length pieces and overlap the ends.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
hotjag1
Lake Chelan, Wa/Lake Havasu, Az.
Posted: 09/27/19 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
I've been using Eternabond tape for over 20 years on several motorhomes. I love the stuff. Once it's on, it's on for good and no more seam worries.
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
hypoxia
Arizona
Posted: 09/28/19 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Putting it in the freezer before use makes it more manageable.
Jim
2007 Monaco Signature Noble III ISX 600HP
hedge
Airdrie, Alberta, Canada
Posted: 09/28/19 09:05am Link  |  Quote  |  Print  |  Notify Moderator
I like to put Dicor on the edge, it seems the adhesive on the edge attracts dust/dirt and looks bad if you don't.
2017 F350 Platinum DRW
2013 Adventurer 89RB
