RV.Net Open Roads Forum: Class C Motorhomes: Anyone here upgraded their headlights?
 > Anyone here upgraded their headlights?
suprz
rhode island
Posted: 09/28/19 01:51am Link  |  Quote  |  Print  |  Notify Moderator
My 2006 E450 headlights are "ok" I guess for regular night driving, but my eyes aren't what they once were. Are there LED conversions for these headlights? I have never changed one, so I don't even know if it's a sealed beam or a bulb kind of set up. Just looking for ideas for upgraded lighting for driving at night when it's necessary
Proud father of a US Marine
gbopp
The Keystone State
Posted: 09/28/19 07:01am Link  |  Quote  |  Print  |  Notify Moderator
I have not done it yet, I am considering converting my Chevy Suburban to LED.
I did run across this article on converting RV Headlights to LED.
It may give you some helpful information.
pianotuna
Regina, SK, Canada
Posted: 09/28/19 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I added some "light bars" for about $70 cdn. My low beams now give me better lighting than my high beams. The bars have their own separate switch but can only be on when using the low beam setting.
Regards, Don
jfkmk
NJ
Posted: 09/28/19 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Noise, radio interference, flickering, poor light distribution, and blinding other drivers can all be associated with sticking LED bulbs into a housing designed for halogen lights. Don’t cheap out and you can alleviate some of these issues. Add on light bars are designed for off road use and are, most likely, not legal to use on the road (although that doesn’t stop a lot of people).
enblethen
Moses Lake, WA
Posted: 09/28/19 08:40am Link  |  Quote  |  Print  |  Notify Moderator
I installed a pair of driving lights. Angleing them toshoulder for left and nearly straight for right light.
I wired them through a switch and a relay to have them on most of the time, day and night. They serve two functions, daylight running lights and driving lights.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
garyhaupt
Penticton, BC..land of wine, sun, retirees....
Posted: 09/28/19 08:45am Link  |  Quote  |  Print  |  Notify Moderator
I did, but I am lost trying to recall just exactly what. I bought Sylvania plug n light...no big deal..except I had to go to a dealer to get the removal figured out.
The other thing to be mindful of is the front plastic on the your headlights is probably fogged. You can some ideas on You-tube on how to clean and that alone will improve your lighting.
Gary Haupt
I have a Blog..about stuff, some of which is RV'ing.
http://mrgwh.blogspot.ca/
HadEnough
Traveling. Always.
Posted: 09/28/19 10:00am Link  |  Quote  |  Print  |  Notify Moderator
I have tried this a couple times. I have found no joy. I cleaned my headlight lenses and got the cloudiness off, but I still have yellow, dim lights that I can’t see well with.
I bought the most expensive Bulbs in Walmart. That doesn’t say much. They are great on highbeam, but went on low beam, they are yellow and dim still.
Can anyone recommend a product that will be bright at the same time it is pointing low toward the ground? Looking for that cooler temperature light. It makes sense for headlights. It keeps you awake. Everything is just more clear with it.
bobndot
Posted: 09/28/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Whatever you decide to do, after you make the change , have another person drive another vehicle in the opposite direction as you to make sure you are not blinding other drivers or airline pilots.
I'm sure in the populated area where you live there are auto shops that can steer you in the right direction as to which light and lens to choose. Something like pianotuna installed might be your best bet as long as you purchase the correct light. I found it's not the best idea to cheap out on lighting, buy a quality light and wiring.
Dakzuki
Carnation, Wa, USA
Posted: 09/28/19 11:38am Link  |  Quote  |  Print  |  Notify Moderator
....and legality. Most aftermarket LED setups are not DOT approved.
2011 Itasca Navion 24J
2000 Chev Tracker Toad
Oceano Dunes, CA
Posted: 09/28/19 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
Nope but I added a light bar behind the Silverado’s grill.
