RV.Net Open Roads Forum: Class C Motorhomes: Anyone here upgraded their headlights?
 > Anyone here upgraded their headlights?
pianotuna
Regina, SK, Canada
Posted: 09/28/19 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
Gary,
Toothpaste will clean the lenses. It is temporary, but so are the commercial cleaners.
Regards, Don
Iraqvet05
Greenwood, MO
Posted: 09/28/19 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
I suspect your headlights are sealed beam glass...at least my 2008 Super Duty still have factory sealed beams. Your option would be to swap out the headlight assembly for an aftermarket LED, replace your sealed beams with a better sealed beam (ie Sylvania ExtraVision) or add supplemental lighting.
You have to be careful with aftermarket LEDs as the cheaper ones do cause radio interference or have poor light distribution. I have quality aftermarket LED bulbs in my F-250 and have them adjusted down. The cut off is great and I don't get flashed and the truck passes state inspection. I've asked several police in the department I work for (I'm the city mechanic) and the consensus I got was they don't write headlight tickets unless you have one out or you are using supplemental lighting (light bars, driving lights) as your primary lights instead of your headlights.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
amxpress
Clayton, NC
Posted: 09/28/19 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Some very good responses. People don’t realize that when they replace their halogen bulb with an LED, the light housing isn’t designed to work well with LED’s resulting in blinding the oncoming traffic. Most don’t aim their lights, either.
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L is out of state, out of touch, and out of her mind
klutchdust
Orange, California
Posted: 10/01/19 09:49am Link  |  Quote  |  Print  |  Notify Moderator
I replaced my headlights with LED's . All that was required was to find a wall and re adjust the lights. On the Ford chassis there are NO adjustments for side to side only up and down. Since I replaced my headlights to LED's I have not had anyone "flash" at me.
The upgrades are easy to install and work well. They fit exactly as they are supposed to in the housing.You tube video shows the purchased exactly how to install them.
Chum lee
Albuquerque, NM
Posted: 10/02/19 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Turn on the headlights at night and open the hood. Are the back of the headlamps glowing? If so your reflectors have degraded and some of the generated light is shining in the wrong direction >> out the back instead of the front where it is then degraded by the yellow lens. If cleaning/polishing the yellow lens doesn't help, the only fix is replacing the headlamps. They are available online most of the usual FLAPS, Ebay, Amazon, etc.
FLAPS = Friendly Local Autoparts Stores
Chum lee
AJR
Close to Madison Wisconsin
Posted: 10/03/19 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
If your eyes are not what they once were. Go to an eye surgeon and see if you need cataract removal.
I waited way too long to have that done. It makes things back to normal driving. Plus you can see things in front of you with a strong light behind it.
2014 Leprechaun 290QB
Chevy 2400 6.0
2015 GMC Terrain AWD
macjom
Fl
Posted: 11/05/19 11:31pm Link  |  Quote  |  Print  |  Notify Moderator
I agree. Unless you can put a projector for a headlight retrofit.
ron.dittmer
North-East Illinois
Posted: 11/06/19 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Regarding the Ford E350 and E450 chassis made 2007 and older, just about every motor home will NOT have a sealed beam. Only the generically styled work van has them. According to my 2007 owners manual, the nicer styled non-work van version (see my signature picture) is called "aerodynamic" and the replaceable bulb filament is 9007. So if your Ford E350 or E450 chassis is a 2007 or older with the previous grille styling, then bulb 9007 is the one to use.
Now........
There are bulb manufactures like Sylvania for example that offer brighter 9007 bulbs. Now-a-days every standard headlight is halogen, but the bulb companies are offering brighter versions using the same technology.
Two nights ago, I replaced our son's headlight bulbs on his Hyundai Elantra with a brighter halogen offered by Sylvania, sold in a twin pack at Walmart. They are called "SilverStar Ultra" Comparing his original used working bulb to one new bulb, we both agreed the new SilverStar Ultra was noticeably brighter. Then we replaced the old but working bulb to match.
Here is Walmart's extra bright 9007 bulb offering. I don't know if a 2008 or newer E350 or E450 takes this same bulb, but the 2007 and older surely do. I was thinking of buying a pair for our motor home, now this subject has come up....hmmm.
According to my 2007 owners manual, my E350 headlight bulbs can be changed without tools, seemingly in just seconds. With hood open, on top of the lens are two tabs. I lift them to a clicking stop, then the headlight lens comes right out for total access.
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
DrewE
Vermont
Posted: 11/06/19 06:56am Link  |  Quote  |  Print  |  Notify Moderator
Brighter bulbs (like the Silverstar Ultra) are indeed brighter than standard bulbs, but that comes at the expense of very significantly reduced bulb life (which is usually listed in the small print on the back of the package, though I'm not sure if there is any standard across manufacturers for the tests). Particularly if you do a fair bit of night driving, that may be a worthwhile consideration.
The reason for the reduced bulb life is pretty straightforward: they burn hotter, in order to be brighter, and so burn out more quickly. As the saying goes, there ain't no such thing as a free lunch.
klutchdust
Orange, California
Posted: 11/06/19 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Check out Headlight revolution.com for expert advice .
