RV.Net Open Roads Forum: Class A Motorhomes: F53 rear diff service
 > F53 rear diff service
dodge guy
Bartlett IL
Posted: 09/28/19 06:28am Link  |  Quote  |  Print  |  Notify Moderator
Hello. Planning on changing the gear oil on my new to me 2012 F53. I've got the fluid, not the issue. I can't find anywhere on what is needed to change it. I'm assuming there are drain no fill plugs, but can't verify it, the RV is in storage right now so I can't climb under and look at it. Just wondering if anyone has physically done it and can verify!
Yes I know it's filled for life, but I have never bought into that, especially after seeing trans fluid that's filled for life after 50k miles! BTW I am doing my trans and brake fluid also. And probably PS fluid. Coolant has already been done.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
sailor_lou
Connecticut
Posted: 09/28/19 06:43am Link  |  Quote  |  Print  |  Notify Moderator
I can't speak specifically on a 2012 chassis, but typically there is a drain on the bottom and a fill on the side at the correct height level. They both should be a 1/2" square drive plug in which you simply use a ratchet to remove and reinstall. If possible, drain when warm and then refill until the level is at the bottom of the fill plug hole. Simple, easy and I agree, replacing lubricants is always a good idea. Good luck.
Lou
05 Travel Supreme Envoy
MountainAir05
New Mexico
Posted: 09/28/19 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Lou hit it on the dot. I change out all my fluids. The new synthetic gear oils last longer, and you see it when you change them out. No where as black as the old stuff.
dodge guy
Bartlett IL
Posted: 09/28/19 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Ok thanks. I'm a tech and some trucks have them and some don't. However this is the first time doing it on an axle this big. I was figuring it had 3/8 or 1/2 inch drive plugs but wasn't sure. And yes I plan on doing it in the driveway immediately when it comes home from storage (when it's warm).
77rollalong
Brighton Ontario
Posted: 09/28/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
most diffs dont have a drain hole, the fill on most is on the back of the diff cover, some are also on the side of the diff case..
Home Skillet
Pearland Texas
Posted: 09/28/19 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Correct.
The rear cover will need to be removed to drain the fluid.
You would need some RTV silicone to reseal the cover.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
Pirate
Northeast Tennessee
Posted: 09/28/19 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Home Skillet wrote:
Correct.
Gee, my 2006 has a drain plug, perhaps they got cheap with the 2012 or maybe some folks don't know what they are talking about.
amxpress
Clayton, NC
Posted: 09/28/19 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
If your differential does not have a drain plug, check this out before you go pulling off the cover:
Oil pump
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L is out of state, out of touch, and out of her mind
Home Skillet
Pearland Texas
Posted: 09/28/19 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Key word is "most".
Sheesh. [emoticon]
dodge guy
Bartlett IL
Posted: 09/28/19 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Well there is no cover on these rear ends. It has a drop out center section. I looked up ford parts and there is a drain plug in the bottom of the axle housing, and a fill plug up higher.
