RV.Net Open Roads Forum: General RVing Issues: Dead microwave
 > Dead microwave
Hokiehall
Lynchburg, VA
Posted: 09/28/19 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Our microwave died on our last trip. It is a built in Magic Chef MCD991ARB. I have pulled it out. Does anyone know of a suitable replacement? We will be limited on size due to its location. Thanks in advance.
ppine
Northern Nevada
Posted: 09/28/19 08:49am Link  |  Quote  |  Print  |  Notify Moderator
Use the space for storage.
12th Man Fan
Flower Mound , Texas
Posted: 09/28/19 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Most microwaves have an internal fuse. Did you check that?
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
midnightsadie
ohio
Posted: 09/28/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
measure your size and head for wal mart.
Hokiehall
Lynchburg, VA
Posted: 09/28/19 09:28am Link  |  Quote  |  Print  |  Notify Moderator
It will run for 2 seconds and cut off. Clock is still working on it.
Hokiehall
Lynchburg, VA
Posted: 09/28/19 09:29am Link  |  Quote  |  Print  |  Notify Moderator
They didn't have one that small. At least ours didn't and we have two close by.
Fresno Tundra Driver
Fresno,Ca. USA
Posted: 09/28/19 09:36am Link  |  Quote  |  Print  |  Notify Moderator
I found our replacement microwave at Best Buy for about $100...
E.Lee Galik
George3037
Central Square, NY
Posted: 09/28/19 10:01am Link  |  Quote  |  Print  |  Notify Moderator
I recently bought a used Class A and my microwave did the same thing. I had put a cup of water in to test it. It ran for a few seconds then stopped. The clock still worked fine but not the microwave. After numerous tries I found the door was warped slightly. The upper latch makes the internal switch to allow it to work. Apparently the upper door latch was not fully engaging the switch.
I opened the door and slightly twisted the door (pushed top in and pulled bottom out) as to not break the glass. Closed the door and it has worked fine since.
I know you've already pulled it out but try this. Next time you try yours and if it runs a few seconds then stops, try pushing in the top of the door.
Thunder Mountain
Lost in the Four Corners
Posted: 09/28/19 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Do a Google search for "microwave runs for two seconds and stops." It's not an uncommon issue and fixable. I think I remember is being discussed on this forum.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2013 Keystone Outback 250RS
2013 Ford F150 FX4 Ecoboost
2 Arctic Cats
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
SidecarFlip
SE Michigan
Posted: 09/28/19 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Microwaves are so cheap, a broken one only demands to be landfilled.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
 > Dead microwave
