RV.Net Open Roads Forum: Experience towing w/ 2WD F250, 2500 or other 3/4 ton
 > Experience towing w/ 2WD F250, 2500 or other 3/4 ton
Nighduckman
Virginia
Posted: 09/29/19 08:46am Link  |  Quote  |  Print  |  Notify Moderator
My wife and I recently bought a Jayco Eagle HT 24.5 CKTS fifth wheel. After being somewhat taken in by the marketing and our Ford dealer, we bought a beefed-up F150 that, in the end, was overweight on GVR and the rear axle rating. For safety and out of an abundance of caution, after much research, we traded it in for an F250, gas engine, 2WD. We got the 4x2 instead of the 4x4 because it is a much better fit, height-wise, with our fiver and because we are not going to boondock and only camp in prepared campgrounds with decent roads. I understand we will likely get stuck once in a while, but, will have a tow strap and I understand we can usually count on a nice 4x4 owner to tow us out and/or we have GoodSam towing assistance. Again, we are not going to off road or seriously boondock. We won't be driving the rig in snow etc.
Having said all that, I am curious about the real-world experience of any others who have towed with 2WD. We are comfortable with our decision and know there will be tradeoffs over 4x4 like much lower resale and, potentially, getting stuck occasionally. But, all in all, mainly interested in what other 2WD towers have experienced. Thanks in advance.
Second Chance
Wherever...
Posted: 09/29/19 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Forum rules prohibit posting the same content in two sub-forums.
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
Devocamper
West Haven CT
Posted: 09/29/19 09:01am Link  |  Quote  |  Print  |  Notify Moderator
In 11 years of towing a 15600# fifth wheel we used 4wheel drive in relation to towing one time on a wet grass campsite pulling up a small hill . But it is the kind of option that when that day comes, and it will , you will think back and question your decision to go with rear wheel drive. We currently have a rear wheel drive truck but we did it to increase our payload capacity since we now carry a TC and are willing to take the chance on needing 4 wheel drive at some point. We have been on wet grass with the TC and have not had any problems so far . Our TC puts almost all it weight on the rear axle so when I do get stuck it will be my rear tires sinking into grass or mud andI probably would need a tow anyway .
Mike
08 NU-WA Hitchhiker Discover America 339 RSB Sold
18 Host Mammoth
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A Sold
18 Ram 3500 SLT Crew Cab DRW 4x2 6.4 4.10's
MWJones
Posted: 09/29/19 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Nightduckman,
I hope you got the 3:73 rear end with the locking differencal . If so, you have the "perfect" set for your rig, in my opinion.
M Jones
American and Texan by birth
Christian by the Grace of God
Retired and enjoying Traveling and Camping
Spending part of summers in South Fork, Co
romore
Okanagan valley British Columbia
Posted: 09/29/19 09:24am Link  |  Quote  |  Print  |  Notify Moderator
I have a Ram 2500 2wd which has worked well for towing, I have yet to get stuck in a campground. My petite gf has enough trouble getting in and out of it, 4wd is not in the cards. It also rides smoother than my buddy's nearly identical 4x4.
Nighduckman
Virginia
Posted: 09/29/19 09:28am Link  |  Quote  |  Print  |  Notify Moderator
We did get the 3.73 locking rear axle. Thanks! We have decided that, if it ends up that we get stuck constantly, we will swallow our pride, raise our fiver to fit and get a 4x4 but, based on what I am hearing from others who camp the way we plan to, we figure we will only need a tow once in a while, if that. And we would also have to accept not getting much in trade-in. But we are comfortable with that cost should it ever prove necessary to enjoy this new to us recreational activity.
Tyler0215
Iowa
Posted: 09/29/19 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Have had a 4x4 for two years, needed it once.
BarneyS
S.E. Lower Michigan
Posted: 09/29/19 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I towed for about 25 years with a 4X2 and only need a tow one time. Got stuck in soft grass at a campground site and was pulled out by a fellow forum RVer with a 4X4.
Could have used it one other time just for peace of mind when going up a very steep gravel incline to a campground. Made it ok but was spinning wheels and spitting gravel part of the way.
My preference is for 4x2 but need a 4X4 now since we are spending our time in Michigan winters now instead of going to Florida for the winter. [emoticon]
Barney
Not towing now.
goducks10
There
Posted: 09/29/19 10:07am Link  |  Quote  |  Print  |  Notify Moderator
I've towed with both. Only times I've needed 4wd was when backing up on the leveling blocks on a gravel surface and traveling down a few gravel roads where the road had some bad washboard on uphill curves.
Since you don't boondock I'm guessing you'll be fine.
topjimmy
Washington Coast
Posted: 09/29/19 11:07am Link  |  Quote  |  Print  |  Notify Moderator
When I was fulltiming I had a 1 ton GMC Dually 4WD hauling my 14K 5er and it worked Fantastic but now I am part time so I sold the Dually and Am now towing it with a 2500HD GMC shortbed 2WD Duramax with airbags and It does it better than I thought it would and I have never been in a situation where I needed 4WD and works great for shorter trips if I went back to fulltime it would be back to a Dually 1 ton 4WD And MAN do I like driving the shortbed around town better and so does my wife[emoticon]
2015 Montana 3735MK Legacy,2004 2500HD GMC Short Bed, LB7 Duramax/Allison ,Pacbrake,Firestone Airbags Bullydog Tuner
