RV.Net Open Roads Forum: Class C Motorhomes: Hydraulic leveling legs making noise
 > Hydraulic leveling legs making noise
okiejoe
Oklahoma City
Posted: 09/30/19 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hey you all, I’ve been doing some regular maintenance stuff and in checking out my hydraulic levelers on my C everything works great except when retracting all jacks after all 4 jacks are up the pump continues to run sounding like it’s still retracting but only for about 5 seconds. I don’t seem to remember it doing that before. I did add some hydraulic fluid and run the system a few times and checked for foam but all loooked well. Any thoughts. ?
* This post was edited 09/30/19 03:08pm by okiejoe *
MDKMDK
Canada
Posted: 09/30/19 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
okiejoe wrote:
Hey you all, I’ve been doing Tom regular maintenance stuff and in checking out my hydraulic levelers on my C everything works great except when retracting all jacks after all 4 jacks are up the pump continues to run sounding like it’s still retracting but only for about 5 seconds. I don’t seem to remember it doing that before. I did add some hydraulic fluid and run the system a few times and checked for foam but all loooked well. Any thoughts. ?
I'd ask Tom. If it's his regular maintenance you're doing.
It's probably normal. If the jacks retract, all is well.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
okiejoe
Oklahoma City
Posted: 09/30/19 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
I corrected Tom to Some
klutchdust
Orange, California
Posted: 10/13/19 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
When you say you added "some" fluid, how much?
Extend the hydraulics fully then retract fully. Check fluid once retracted.
There may be a few air bubbles in there.
Use fluid specifically for hydraulics, not power steering fluid or ATF.
