RV.Net Open Roads Forum: Travel Trailers: Reese Sway Control Bar
 > Reese Sway Control Bar
atrerice
Michigan
Posted: 10/02/19 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Finishing up the first season with our TT and decided to get a friction sway control bar for our next trip. We have the Reese style hitch head with trunion style springbars. The hitch head already had the little sway control ball installed as well as on the TT. My question is about dialing in the amount of friction. How much friction should there be? Out of the box, it's tightened enough to where I can't slide the bar in or out at all. If I loosen the "On Off" lever, pull the bar out and tighten the lever back, if I put all my weight on it, it will barely slide back in. We towed the TT about 1,000 miles this year without much sway at all. Just wanted to add the swaybar for additional safety. Any suggestions would be greatly appreciated!
Thanks in advance!
DutchmenSport
Indiana
Posted: 10/02/19 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Loosen the friction sway bar so it slides easily by turning the crank handle. After installing on both little balls, tighten the handle crank as much as you can by hand. Give it an extra "umph" and that's good. The tighter it is, the better it helps control sway. But there is a point where too tight is too much, so never use a cheater bar to make it tighter. However, it is OK to use a cheater bar if you need to initially loosen it.
Once it slides easily, remove it from both little balls until needed the next trip. I used one for years and years. I had to replace it once with a new one as the old one finally froze in place and I ended up breaking the handle to when attempting to loosen it. That was after 10 years of use too.
bgum
South Louisiana
Posted: 10/02/19 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
Too tight will pop the ball off. Check online sites for proper use. YouTube or etrailer etc
* This post was edited 10/02/19 08:11pm by bgum *
Owens River Road, California
Posted: 10/02/19 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
What is your tongue weight percentage?
ScottG
Bothell Wa.
Posted: 10/02/19 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
If you have the trunion style bars, add the dual cam kit to it.
Works far better than simple friction.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
wing_zealot
East of the Mississippi
Posted: 10/03/19 04:57am Link  |  Quote  |  Print  |  Notify Moderator
It sounds like from your description you had it about right. Drive with it a while, if it seems like you need a little more, tighten the bolt on the back a little. If it seems to much, loosen the bolt on the back. Over tightening it will break the balls off.
Lynnmor
Red Lion
Posted: 10/03/19 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
This is totally incorrect and the reason that so many find fault with the friction bars. Read the directions.
atrerice
Michigan
Posted: 10/03/19 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys! The biggest thing I worry about is having it too tight and having it break the hitch head or the trailer tongue. The thing is with these things is there really isn't a whole lot of information out there about adjusting them. Watched a few YouTube videos but it sounds like it's more trial and error than anything else.
camperforlife
Midwest
Posted: 10/07/19 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
I had two on a 26' trailer for years. Tighten it down tight and back off until the handle is parallel to the bar. If you tighten it too much during a sharp turn you will either bend the bar or break the little ball off or both. For the first few times that you use a new friction grip sway control pull out the bar after use and clean off the friction residue with course steel wool. The residue can cause it to stick and damage the bar. Always take it off before you make a sharp turn backing up. Going forward it is highly unlikely that you will ever make a sharp enough turn to damage it.
Lynnmor
Red Lion
Posted: 10/08/19 12:03am Link  |  Quote  |  Print  |  Notify Moderator
The handle is NOT the adjustment, read the directions.
