RV.Net Open Roads Forum: Travel Trailers: Tankless Water Heater Compatibility?
 > Tankless Water Heater Compatibility?
sean4fsu
Posted: 10/03/19 05:16am Link  |  Quote  |  Print  |  Notify Moderator
Tankless electric water heaters are so expensive, and I was wondering if anyone knew if this model would work in our 2007 Terry Travel Trailer Camper? I would like to use it for our shower.
https://www.ebay.com/itm/NEW-Rheem-Electric-Tankless-Water-Heater-6kW-RETEX-06-Self-Modulating-SEALED/143340591004?epid=20021167549&hash=item215fc3d79c:g:jcsAAOSwxuRdGyAQ
https://www.rheem.com/product/performance-tankless-electric-3-6kw-electric-water-heater-with-5-year-limited-warranty-retex-06/
And if it does fit, how would we convert it to be used in our camper?
* This post was edited 10/03/19 05:48am by sean4fsu *
valhalla360
No paticular place.
Posted: 10/03/19 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Assuming you have a 30amp/120v camper...no it won't work.
- Unit is 220v.
- Unit is 6,000w (6kw)...30amp/120v maxes out at 3600w.
If you have a 50amp rig, it may be possible if you rig up a 220v circuit but you may need to manage what is being operated as the water heater will eat up around 60% of available capacity by itself.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
cavie
Posted: 10/03/19 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Nope won't work as stated above. Also if you don't have shore power and don't have a 220 volt generator you won't have hot water.
Dick_B
Palos Heights, IL USA
Posted: 10/03/19 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Before you spend any money search this Forum for `tankless' and read the previous posts.
IMHO a tankless water heater would be a good idea for a park model that never moves BUT never for rv's that move around.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
GrandpaKip
Flat Rock
Posted: 10/03/19 07:32am Link  |  Quote  |  Print  |  Notify Moderator
I would consider a propane model if/when our water heater bites the dust, but not an electric one.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
cavie
Posted: 10/03/19 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Sure is nice to flip a switch when the gas runs out in the middle of the night.
wanderingaimlessly
SOBOVA
Posted: 10/03/19 08:58am Link  |  Quote  |  Print  |  Notify Moderator
Here is the data from AP tankless that makes a lot of these units. (Steibel US/Canada models)
Tankless
The AQC 3.1 is the only 120 Volt model, it will warm a half gallon per minute flow by 40 degrees F. And will be drawing 25 Amps doing it.
NOT an RV frendly unit.
There are some gas operated ones made for RV use.
ScottG
Bothell Wa.
Posted: 10/03/19 09:00am Link  |  Quote  |  Print  |  Notify Moderator
X2.
And the propane models keep getting better. I've used a propane model in a house that worked fantastic - couldn't tell it from elect.
Not sure if RV units are that good yet but we would sure like to go that direction some day.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
philh
Belleville MI
Posted: 10/03/19 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Ask yourself a more fundamental question, why do you need unlimited hot water?
sean4fsu
Posted: 10/03/19 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
I appreciate all of the helpful ideas and suggestions!
Kim and I are going to be living in our Terry Travel Trailer Camper for another 5 years, and we don't want to spend money to fix our current non-working water heater which needs a circuit board, and only to have it eventually have the water heater in our camper break down and then have to buy another one for over $800 so we thought a tankless water heater would be a better idea for our finances.
Does anyone have any suggestions that we can check out that would save us from having to eventually buy an over $800 water heater? Because also, we have been living in the camper for 5 years already at an RV park here in town.
