RV.Net Open Roads Forum: Tow Vehicles: Lowering TV tire pressures
Search only in Tow Vehicles
 > Lowering TV tire pressures
Page of 12
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 10/04/19 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
On my 2015 SRW 3500 I run 60 in the front all the time. Unloaded I run 40-42 in the rears. LT275/70R18E's are rated at 2270 at 40 PSI. So 4540 for the rear axle that weights around 3200-3300 empty. Ride greatly improves at lower inflation. At 60K and 4 years tread wear is even across the tires. Chris
* This post was edited 10/04/19 08:03pm by Me Again *
Cummins12V98
on the road
Posted: 10/04/19 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Me Again wrote:
On my 2015 SRW 3500 I run 60 in the front all the time. Unloaded I run 40-42 in the rears. LT275/70R18E's are rated at 2270 at 40 PSI. So 4540 for the rear axle that weights around 3200-3300 empty. Ride greatly improves at lower inflation. At 60K and 4 years tread wear is even around the tire. Chris
BUT, BUT the sidewall says 80 psi MAX. [emoticon]
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Me Again
Posted: 10/04/19 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, Max load 3640 at 80 psi inflation. Some have a hard time understanding what that means. Tire state Max load, not max inflation.
97chevor
US
Posted: 10/04/19 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
I run 80 psi all tires all the time. The reason being it's easier and more time to spot a tire going flat.
I have driven many miles. Lower starting pressures builds more heat. It actually inflates the tire the longer driving. Too much heat causes blowouts.
AlmostAnOldGuy
Oregon
Posted: 10/04/19 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
How about the inflation table
Not interested in running over inflated. Ride is more harsh and less performance.
2012 F150 HD/Max Payload (8200 GVWR, 2176 payload) SuperCrew EcoBoost
2008 Komfort Trailblazer T254S
Greene728
Newnan
Posted: 10/04/19 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
This only applies if the tire is overloaded and under pressured. If the lower pressure is adequate for the amount of weight on the tire then there's no problem.
I too have a 3500 SRW Ram/Cummins and run 55-60 front year around and 75 loaded/towing and 50 non loaded on the rear. At 50 on the rear according to my TPMS even in the hottest of days here in Georgia the highest heated pressure I've ever seen is maybe 55-56 and no excessive heat on the tire
2011 Crossroads Cruiser 29BHX (Traded)
2017 Grand Design 303RLS
2015 Ram 3500 CC 4x4 6.7 Cummins
Me and the wife and our two daughters. Life's good!
Cummins12V98
on the road
Posted: 10/04/19 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Blindly running at full inflation can give rough ride, longer stopping distance and poor tire wear. Weight/inflation tables are there for a reason!!!
JIMNLIN
Oklahoma
Posted: 10/05/19 06:46am Link  |  Quote  |  Print  |  Notify Moderator
My '03 Dodge/Cummins came with LT265/70-17 E. The door post says 50 psi front and 80 psi rear and came from the dealer as such. The trip home the front tires had the roll over feeling. A RR showed the outer edges were badly scuffed so I did a chalk line test. I increased psi to 65 which gave the 115k miles of service empty or loaded with GN's and 5th wheel rv trailers.
Ran the chalk line on the rears and it showed 45 psi allowed a full tread contact patch. Like the front tire they ran for 115k miles till they finally wore down to just before the tread wear indicators.
After owning eight different one ton DRW trucks for my hauling business.....six 1/2 ton trucks.....four 3/4 ton trucks I could care less what the door post psi says.
I'm tight so I use the best pressure that gets the best tire milage/ride comfort for my tires.
Living out here (rural roads and interstates) will give my vehicle longer tire mileage over city driving.
wilber1
Abbotsford B.C.
Posted: 10/05/19 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Load inflation tables just give the maximum loads for different pressures, they are not recommended pressures.
Vehicle recommended pressures are a compromise between load capability, handling, stopping and ride.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
Me Again
Posted: 10/05/19 08:08am Link  |  Quote  |  Print  |  Notify Moderator
The door jam sticker is for the MAX GAWR of each axle individually. Our 2001 RAM paper work actually had an included document to show inflation for lighter loads.
If you believes in leaving an axle weighing 3200-3400 when empty at 80 PSI, why are you not inflating your fronts to 80 PSI? Oh, wait manufacturer said you only need 60 PSI for that lighter axle load!! Which reminds me, I need to lower my rears to 42 PSI as I will not be towing again for 7 months.
* This post was edited 10/05/19 08:51am by Me Again *
Page of 12
