RV.Net Open Roads Forum: Tow Vehicles: Lowering TV tire pressures
Search only in Tow Vehicles
 > Lowering TV tire pressures
Page of 12
Cummins12V98
on the road
Posted: 10/05/19 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry if I ran 80 in my four rear tires towing my 5,800# pin it would be a **** rough ride. 65 is for max RAWR that I do run. It says so on my door jamb.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
BenK
SF BayArea
Posted: 10/05/19 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
a little more details and not for everyone...make your own decisions, and there is not one size fits all...
I test all my vehicles whenever the season changes, terrain changes, etc. ABS is tested about once a month and more often if the weather changes.
The Nissan Frontier is fairly new to me and am not totally comfortable getting it sideways in inclement weather...yet. The Bilstien shocks are the first mod, as the ones that came with it were too mushy. It still understeers, whereas my Sub is dialed in to neutral and easily induce either under or over steering via throttle or brake
The mini van is stock..except for the P225/65R16’s & KYB shocks...it is just a mini van that is my daily. Even with a 65 aspect ratio..the OEM rims allows too much sidewalk bend back....therefore more sidewall roll over during hard cornering..why the tires are aired to 44PSI, the max sidewall to manage that sidewall rollover and decreases the slip angle
I due slow way down wherever road conditions become slick
Plus....there are many more aspects of my vehicle setups to write here, but the above might help some understand my conservative advice on these forums...especially to anyone asking....as if they knew the HOW2’s...they would need to ask...and thanks Mich...you nailed what I meant by performance on a tow vehicle forum...
-Ben Picture of my rig
demiles
Maryland
Posted: 10/06/19 05:47am Link  |  Quote  |  Print  |  Notify Moderator
This argument is nonsense. FMVSS requires the vehicle to be tested at GVWR and a lightly loaded vehicle weight with the tires pressures set at the same. Your vehicle is not dangerous with minimal load and tires inflated to recommended pressure on the FMVSS sticker. The Ford Explorer fiasco changed some things.
2008 Jayco G2 28RBS
2016 Nissan XD 5.0L Cummins
JIMNLIN
Oklahoma
Posted: 10/06/19 06:14am Link  |  Quote  |  Print  |  Notify Moderator
op wrote:
For those of you with diesel HD trucks that lower their tire pressures when not towing, what do you set them to?
I’ve currently set 55 front and 60 rear which is a much smoother ride but I’m wondering about the effects. Tire wear? Controllability?
Will lowering the fronts cause steering issues? Since all the weight is up front with the diesel should I lower them at all? In theory, with all the weight up front and little in the rear I should be able to lower the rears to less than the fronts. Any problem with that?
OP has a 2500 Ram with the Cummins and seeks help with unloaded pressures for that truck.
It would help is he and others that are interested in helping him need to add his/their tires size/load range.
Depending on what size the OP tires are 55 psi may or may not work the best. I would think 55 psi with a heavy diesel sitting on them (especially 17" tires) will be under pressured causing premature wear issues/hotter operating temps.....but sure would ride good.
60 psi in the rear tire on a 2500 truck ? Regarles of size IMO 45 psi would be a good place to start. Always moniter tire wear patterns. It a good indicator of your tires pressure needs.
joelc
Cedar Point, NC
Posted: 10/06/19 06:26am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
joelc wrote:
On my tires it states 80 lbs pressure. That is what I leave them at towing or not. However, if you want a softer ride I would follow the guidelines on your left vehicle door jam, but not any less.
Must be a real pleasure riding with you.
At least you know you are safe. The manufacture puts a specific recommended pressure stamped on the tires for a reason. The vehicle manufacture puts another pressure on the door jam so you get a softer ride, but not generally safer. I would vote for the tire manufacturer specs, not the truck manufacturer suggested pressure. Check it out.
FishOnOne
The Great State of Texas
Posted: 10/06/19 06:49am Link  |  Quote  |  Print  |  Notify Moderator
On my 05 Super Duty I experimented with running a lower tire pressure than the truck manufacturer recommended which is 65psi front and rear. Running a set of BF Goodrich tires the first set running 65psi I got ~60k miles and the second set running ~50psi I got ~45k miles. Also running lower tire pressure you can expect to get lower fuel economy as well.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
Cummins12V98
on the road
Posted: 10/06/19 07:30am Link  |  Quote  |  Print  |  Notify Moderator
"At least you know you are safe" That's funny! Properly inflated tires have the best stopping and handling.
See this is the problem when people don't understand what that "MAX INFLATION" means!!!
That is NOT a "recommended pressure". Why do each and every tire out there have weight/inflation charts?
Here is one.
What does it say on the tire in the second pic???
Cummins12V98
on the road
Posted: 10/06/19 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Weigh your truck use chart and add 10psi to front and 5 psi to rear. I would get 100-120K on my 98 with 3rd gen take offs.
Posted: 10/06/19 09:25am Link  |  Quote  |  Print  |  Notify Moderator
^Good one 12V! The tire manufacturer even wrote it in big letters for the folks who are too dense to read the fine print!
This is largely a phenomena on this forum compared to the others I'm on, where folks would rather die on their own sword to defend a position that is it only practically, but officially refuted in writing by the tire manufacturers themselves.
Want to run 80psi on the back of your empty truck? Have at er. It'll drive like a rock, get worse traction in low traction situations, but it's ok. It's your truck and your spleen.
He!!, I do it too. If I unload the camper somewhere, I don't lower the tire pressure for just a couple days, although wish I could if we are back in the woods and the roads are bad. Makes them much worse with rock hard tires, but it's a tradeoff. Can't plug my air hose into a pine tree so I leave em full.
There are 2 sides to the coin and the folks that refuse to even flip the coin over and read the other side are, well, funny.
Something about an OLD dog and a new trick I suppose...
noteven
Turtle Island
Posted: 10/06/19 10:13am Link  |  Quote  |  Print  |  Notify Moderator
I run MAX psi in my tires.
I try to run MAX speed as well. Put Q rated 99mph MAX tires on my 18000lbs MAX toyhauler. Ol Dodge has a time getting to MAX but with MAX throttle and MAX manifold psi it tries. Does better on MAX 80mph roads. Gets hard on fuel but MAX is best.
Do everthin to MAX I say.
Signed,
Max
Page of 12
