RV.Net Open Roads Forum: Tow Vehicles: Lowering TV tire pressures
Search only in Tow Vehicles
 > Lowering TV tire pressures
Page of 12
MFL
Midwest
Posted: 10/10/19 08:40am Link  |  Quote  |  Print  |  Notify Moderator
When my truck was new, it did not handle as well with lowered pressure on the rear, when empty, and yes my placard states 80 psi rear. After the tires seemed to break-in some, it handled more the same, when unloaded, and aired down. As to the ride quality, just 10 lbs less (70 psi) makes a huge difference when empty. I do run the full 80 when towing my FW, and it does handle best at full pressure.
Jerry
97chevor
US
Posted: 10/10/19 09:00am Link  |  Quote  |  Print  |  Notify Moderator
What do the tire manufacturers say is the leading cause of blowouts?
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 10/10/19 09:23am Link  |  Quote  |  Print  |  Notify Moderator
The term blowouts is miss used a lot, not sure I have seen a tire manufacturer use that term.
Blowouts, could be from manufacturing defect, road hazards or overloaded tires!
Heat related failure could be from overload tire or under inflated.
Again from my owners manual
• Over-inflation reduces a tire’s ability to cushion
shock. Objects on the road and chuckholes can
cause damage that result in tire failure.
We have to live with the tire manufacturers CYA for the people that do not take the time to properly inflate their tires for the load they are carrying.
* This post was edited 10/10/19 09:49am by Me Again *
97chevor
US
Posted: 10/10/19 11:59am Link  |  Quote  |  Print  |  Notify Moderator
What I have read on every tire manufacturers site is the number one cause of blow outs is UNDER inflation.
wilber1
Abbotsford B.C.
Posted: 10/10/19 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
wilber1 wrote:
Cummins12V98 wrote:
They recommend using those charts unless you want to blindly run what the manufacturer says that is a CYA for them.
Do you seriously think vehicle manufactures don’t know about those charts and don’t use them as one of the criteria when selecting a tire and determining what pressures are optimum for that particular vehicle?
Look at the door of a newer RAM SRW they call for 80psi rear. No one in their right mind would run 80 unloaded. The dash goes crazy if you lower the air on a 2500. 3500's you can lower without the nanny screaming at you. Of course they know about the charts! They base their psi's on them. Some times!
On my DRW they are right on with 80/65psi for full axle ratings. 80 is correct loaded or unloaded. I use the charts to adjust the rears. I checked yesterday my front and rears both have 8/32" tread remaining. No rotation other than moving fronts side to side with same rotation.
Mine calls for 75 loaded, 45 unloaded. I run 80 and 50.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
blt2ski
Kirkland, Wa
Posted: 10/10/19 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
Oh boy......
Cummins does not IMHO get 100k miles from tire because he JUST follows inflation tables. Does it help. Sure it does!
What gets him those miles, is he appears to do mostly highway miles. THAT is the major key.
If he did City miles like I do, getting 60k miles is a treat! As each time I stop and start, turn a corner, my tires are skidding, spinning etc. Yeah my butt can not tell, the skidding etc is microscopic, but it is happening.
Does it help to follow the charts? You bet it does! It's not over 50% of what miles you will get. Probably less than 30-40%.
Marty
Check RV.Net Blogs at: blog.rv.net
Cummins12V98
on the road
Posted: 10/10/19 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
blt2ski wrote:
Oh boy......
Marty
This is true but it DOES help a BUNCH to have proper inflation.
Most people over inflate their rears and under inflate the fronts.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Posted: 10/10/19 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
blt2ski wrote:
Oh boy......
Marty
And add to it, the cool and often wet climate up here IS easier on tires. Have lived here on the wet side of the PNW, desert southwest, mountains, upper midwest and Alaska.
Tires last longer here than any of those places with the worst being the mountains, followed by the desert.
Wet roads = less traction which (even sub consciously) = lower average rates of acceleration from a dead stop.
Same wet roads that = less traction also = less tire wear from tread scrubbing or gripping during accelerating, turning or stopping. Cool weather = less degradation from heat.
By comparison, the mountains were the worst. 5 years on the front range and western slope of CO driving mountain curves at highway speeds daily just chewed through tires. Rotations required 2-3x more often than up here just to keep the edges and tread feathering from getting out of hand.
Desert living, the extreme heat seemed to chew through tires as well. Moreso front tires feathering from turning than rear tires, where the mountain driving just annihilates the edges of all 4 tires. Living in the mountains is the only place I've ever actually dismounted and flipped tires to get more life out of them because the outside treads would go bye bye by the time the middle was only half wore out.
noteven
Turtle Island
Posted: 10/11/19 07:44am Link  |  Quote  |  Print  |  Notify Moderator
All’s I know is it is tiring loading rocks in my truck to bring it up to the other “MAX” sticker (for weight) every time I don’t have anything real to haul on my MAX psi tires...
Signed MAX
* This post was edited 10/11/19 07:52am by noteven *
Posted: 10/11/19 11:09am Link  |  Quote  |  Print  |  Notify Moderator
^Wish there was a like button.
To the MAX!
Page of 12
