RV.Net Open Roads Forum: Tow Vehicles: Lowering TV tire pressures
Search only in Tow Vehicles
 > Lowering TV tire pressures
Page of 12
wilber1
Abbotsford B.C.
Posted: 10/05/19 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Greene728 wrote:
97chevor wrote:
I run 80 psi all tires all the time. The reason being it's easier and more time to spot a tire going flat.
I have driven many miles. Lower starting pressures builds more heat. It actually inflates the tire the longer driving. Too much heat causes blowouts.
This only applies if the tire is overloaded and under pressured. If the lower pressure is adequate for the amount of weight on the tire then there's no problem.
I too have a 3500 SRW Ram/Cummins and run 55-60 front year around and 75 loaded/towing and 50 non loaded on the rear. At 50 on the rear according to my TPMS even in the hottest of days here in Georgia the highest heated pressure I've ever seen is maybe 55-56 and no excessive heat on the tire
X2
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
Cummins12V98
on the road
Posted: 10/05/19 08:13am Link  |  Quote  |  Print  |  Notify Moderator
"The door post says 50 psi front and 80 psi rear "
That's insane!!! My 98 4x4 with 3rd gen tires and wheels I ran 72 front 35-40 rear unloaded. I would get 100k BFG's and 120K Michelins.
PROPER inflation is EVERYTHING!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Lantley
Ellicott City, Maryland
Posted: 10/05/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Blindly running at full inflation can give rough ride, longer stopping distance and poor tire wear. Weight/inflation tables are there for a reason!!!
I think your right. But logistically I'm not inflating /deflating tires after every trip. I can't imagine everyone else goes through an air up air down ritual each trip[emoticon]
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
camp-n-family
London, Ontario
Posted: 10/05/19 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Some do but I can’t be bothered. Mine are inflated to door sticker pressures for summer towing season. Up north the tt gets put away from oct to May so it makes sense to lower them for that period.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
West & above Bishop, California
Posted: 10/05/19 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting, Parker. Haven’t seen a double sticker in that era.
BenK
SF BayArea
Posted: 10/05/19 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
All of my vehicle tires are aired up to the max = Mini Van, K3500 Suburban and Frontier crew
Performance is on my have to have list and ride quality isn't....ride quality is at the bottom of my nice to have list
All personal choice topic and how/where/etc you drive...there isn't a one size fits all on this topic...as it is with most topics...
Also remind folks of what Ford did solely for ride quality (not for performance) on the Explorer and the subsequent federally mandated dash & tire PSI monitor/warning lite...have to maim/kill folks before it sinks in...
-Ben Picture of my rig
Cummins12V98
on the road
Posted: 10/05/19 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
When I travel south I am at my towing pressures If I am at a site for only a few days I leave the pressures high. If I am there for a couple weeks or longer they get dropped.
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 10/05/19 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
I hope you never have to make a emergency stop in a low traction situation with a pickup with with 80 PSI with no load in the bed.
In talking with Michelin about inflation a couple of times they stated that beside low traction issues, and over inflated tire for the load in more likely to receive impact damage when over inflated for the load.
I do know having owned my 2001 RAM 2500 std cab lb for 14 years that with 80 psi in the rear empty it handle a bit squirrely.
But to each their own. And please do not tailgate me if you are ever behind me.
mich800
Pontiac, MI
Posted: 10/05/19 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with you. It depends on what your primary "performance" trait you are trying to maximize. Because everything is a compromise. Ben's definition of performance is load capacity. Where others may be traction, ride quality, tread life or some combination thereof. There is never any one perfect answer when dealing with multiple mutually exclusive (to some degree) options.
Lantley
Posted: 10/05/19 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
The way I see it this is a towing forum. Max. pressure is generally what's needed for towing. Towing is what we all have in common.
Once we stray away from towing and the discussion turns to groceries,driving across a sandy beach low traction or doing anything else our needs and perspectives will change drastically.
Page of 12
