RV.Net Open Roads Forum: Class C Motorhomes: Suspension upgrade disappointment.
 > Suspension upgrade disappointment.
Jayco-noslide
Galesburg,Il., USA
Posted: 10/04/19 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Our 15 year old Itasca 30 footer gradually became a real chore and dangerous to drive down the road straight. First tried alignment, balance, new tires and change in tire pressure. No improvement. Finally a front end/alignment shop replaced the obviously worn bushings and recommended a "suspension upgrade" and we did replacement all sway bars and added a rear track bar. I'm not sure if this was regarded as a total or just a partial upgrade but the claims were pretty lofty. Now, after 1000 miles I'm somewhat disappointed and still find it hard on my old shoulders to steer all of the time. I think it is better and probably needed done but I don't think it can be even better until the play is taken out of the wheel and no one has addressed that. Have already spent around 5K and really don't want to spend another $1000 or more. Comments?
Jayco-noslide
ppine
Northern Nevada
Posted: 10/04/19 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Vehicles are complicated. There are a lot of parts that wear out over time. It is that one last bushing or control arm that needs to be replaced that makes all of the difference. Do not give up. YOu are almost there.
pianotuna
Regina, SK, Canada
Posted: 10/04/19 09:26am Link  |  Quote  |  Print  |  Notify Moderator
how are the ball joints? tie rod ends?
Length to wheel base ratio is?
Regards, Don
egrove
Dallastown, PA
Posted: 10/04/19 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Are you saying it used to drive better and has now gotten worse? If so, I would look at items that have worn out, instead of adding new parts such as sway bars and track bars. What is the condition of the shocks and other suspension components as Don mentioned?
Eric Grove
Dallastown, PA
2019 Tiffin Open Road Allegro 34PA
View an online map showing campgrounds in the US
Add a Visited States Map to your signature
MDKMDK
Canada
Posted: 10/04/19 09:54am Link  |  Quote  |  Print  |  Notify Moderator
If the steering wheel has too much "play", the steering gears/box might be worth a look. My old Roadtrek (on the 2002 Chevy 3500 Express van) steering wheel had a lot of play in it, but I just got used to it. The other reason I didn't bother fixing it was the parts were obsolete. I could have gotten an after market steering box replacement, but I didn't think it was worth the effort for a bit of extra steering wheel play. I had the wheel bearings replaced, and put new tires on it, and eventually Bilstein shocks, all of which helped the tracking, but I never bothered to get the steering parts replaced.
Maybe you could/should get yours checked?
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
DrewE
Vermont
Posted: 10/04/19 10:01am Link  |  Quote  |  Print  |  Notify Moderator
Definitely check the tie rod ends and ball joints; my first guess would be the tie rod ends. If you have a steering damper (I think that may just be on the E450 from the factory), see if it is worn also--or if it looks worn or leaky, just replace it as they are not all that expensive or hard to replace. When I replaced mine I discovered that it seemed to have an air bubble in it, presumably from having some of the fluid leak out over time, which caused it to be elastic for small movements rather than damping them out...and replacing it had a noticeable positive impact on the steering feel.
mbutts
Farmington MI, USA
Posted: 10/04/19 10:05am Link  |  Quote  |  Print  |  Notify Moderator
I have done the usual upgrades on my E-450 chassis (bigger sway bars, Bilstein shocks, alignment with max caster), but still found the steering "loose".
The MH went on a diet (almost nothing in the rear compartments, fresh tank almost empty, waste tanks empty) and I filled the Ride Rite airbags to their max. I was looking to put as much weight on the front axle as possible by taking it away from the big ol' tail overhang.
The steering improved quite a bit. I'm disappointed that I can't carry much with us, but it is easier to drive.
Mike Butts
DW+DD+DS+Poodles
2017 Forest River Forester 3011DS (first MH!)
Previously 1999 Coleman Santa Fe pop-up, 2007 Kodiak 23SS hybrid, 2013 Sunset Trail 29SS travel trailer
carringb
Corvallis, OR
Posted: 10/04/19 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Most common cause is simply weight distribution. You need minimum 32% of your total weight on the front axle.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
Chum lee
Albuquerque, NM
Posted: 10/04/19 11:59am Link  |  Quote  |  Print  |  Notify Moderator
I guess I'll never understand why people want to "upgrade" their poorly performing vehicle when it doesn't suit them. Why not get it to work, . . . . . right, . . . . . . as it was designed to do, BEFORE you start the upgrade process.
Your vehicle is 15 years old. Things wear out. Unless you specifically KNOW that some component of your vehicle has weak engineering points, just repair it properly (they way it came from the factory) and go from there.
That means replacing worn bushings, tie rods, shocks, etc. Most people are amazed when their vehicle works as it was initially designed. (it's not a race car, it's a truck operating at close to maximum gross weight)
Chum lee
time2roll
Posted: 10/04/19 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
+1 for running across the scales.
675w Solar pictures back up
