RV.Net Open Roads Forum: Class C Motorhomes: Suspension upgrade disappointment.
 > Suspension upgrade disappointment.
suprz
rhode island
Posted: 10/05/19 06:24am Link  |  Quote  |  Print  |  Notify Moderator
MDKMDK wrote:
Jayco-noslide wrote:
after 1000 miles I'm somewhat disappointed and still find it hard on my old shoulders to steer all of the time. I think it is better and probably needed done but I don't think it can be even better until the play is taken out of the wheel and no one has addressed that. Have already spent around 5K and really don't want to spend another $1000 or more. Comments?
If the steering wheel has too much "play", the steering gears/box might be worth a look. My old Roadtrek (on the 2002 Chevy 3500 Express van) steering wheel had a lot of play in it, but I just got used to it. The other reason I didn't bother fixing it was the parts were obsolete. I could have gotten an after market steering box replacement, but I didn't think it was worth the effort for a bit of extra steering wheel play. I had the wheel bearings replaced, and put new tires on it, and eventually Bilstein shocks, all of which helped the tracking, but I never bothered to get the steering parts replaced.
Maybe you could/should get yours checked?
My thoughts also. Once all the bushings etc are gone through, if problem persists, there's only one thing left. Steering box itself
Proud father of a US Marine
Jayco-noslide
Galesburg,Il., USA
Posted: 10/05/19 09:46am Link  |  Quote  |  Print  |  Notify Moderator
I appreciate all of the attempts to help but that seems to be part of the problem. There are so many things that could be done beyond the 5k+ already spent that I could spend another 5 basically at "trial and error".I think I'll put up with it or consider downsizing to an affordable used Class B. And really test drive it to make sure I can live with the drive.
Jayco-noslide
Harvard
51.6N 114.7W
Posted: 10/05/19 10:14am Link  |  Quote  |  Print  |  Notify Moderator
What is your caster set at? Should be on your alignment report.
Here is a link to our experience circa 2010
mgirardo
Brunswick, GA
Posted: 10/06/19 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Some things aren't trial and error. Did you have the ball joints checked? If they haven't been replaced on a 15 year old Motorhome, they are most likely due. The OEM ball joints on our 2009 (2008 chassis) only lasted 7 years.
Our Jayco handled great on the road right from the dealership lot. I could easily drive it 15 hours at a time without undue fatigue. After about 6 years I noticed it was wandering a little. I figured it was time for an alignment. When I took it in, the mechanic told me it needed ball joints. After they were replaced and aligned, it handled even better than new.
Our mechanic charged $950 with an alignment to replace the ball joints with Moog greaseable ball joints.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
klutchdust
Orange, California
Posted: 10/08/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
mbutts wrote:
I have done the usual upgrades on my E-450 chassis (bigger sway bars, Bilstein shocks, alignment with max caster), but still found the steering "loose".
The MH went on a diet (almost nothing in the rear compartments, fresh tank almost empty, waste tanks empty) and I filled the Ride Rite airbags to their max. I was looking to put as much weight on the front axle as possible by taking it away from the big ol' tail overhang.
The steering improved quite a bit. I'm disappointed that I can't carry much with us, but it is easier to drive.
My 09 Cambria had some upgrades when I purchased it and I added Bilsteins. I too put my coach on a diet, moved heavier items up front . I still carry the max in my water tank but the air bags make a big difference. Also, original poster, try different speeds. mine starts getting weird above 62. My recent trip towing my 12 foot trailer with a Polaris Ranger on it, I drove 55. Not only did my mileage improve by up to 2 Mpg but the handling was pleasantly different.
I may just keep it in the 50's next trip without the trailer and see how it goes.
