RV.Net Open Roads Forum: Fifth-Wheels: Does an absorption refrigerator need winterizing
 > Does an absorption refrigerator need winterizing
howardwheeler
West, Texas
Posted: 10/04/19 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
Since an ammonia based fridge has water in the system, does it need some form of winterization? Our camper will spend its first winter in really cold temps. Northern Idaho can get down to minus 35. It’s always wintered in Texas before, so the question has never arisen. If it needs some protection the only thing I could think of is to leave it plugged in on a setting that will cause it to run periodically since you can’t get into the system. I am assuming nothing is required, or I’d be hearing of more problems with these types of fridges. So the ammonia must act as an antifreeze. Am I correct? I don’t want a bad fridge come spring.
ScottG
Bothell Wa.
Posted: 10/04/19 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
There is nothing to winterize on an absorbtion fridge unless it has an ice maker.
Just turn it off and prop the doors open.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
howardwheeler
West, Texas
Posted: 10/04/19 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. I thought that might be the case then started wondering about the water in the system.
noteven
Turtle Island
Posted: 10/04/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Yes! Mine likes Arizona
pianotuna
Regina, SK, Canada
Posted: 10/04/19 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
If you are going to run it in cold weather, yes there are some things to do.
If you are storing it--it will be just fine.
Regards, Don
wildtoad
Blythewood, SC
Posted: 10/04/19 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
Please expound on this.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
RKW
Four Corners, New Mexico
Posted: 10/04/19 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
The water in an RV absorption refrigerator is always in a solution with ammonia. When the refrigerator is in use the solution is weak. When it's not in use the solution is strong. The strong ammonia solution acts as an anti-freeze.
Ryan
  • 2015 Ford F250
  • 2015 Rockwood Signature Ultralite 8280 WS
  • Dual Honda EU2000i Generators
    The wages of sin are death; but after they're done taking out taxes, it's just a tired feeling.
  • ScottG
    Bothell Wa.
    Posted: 10/04/19 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
    Unbelievable. Amonia freezes at -107F .
    The OP's fridge is NOT going to freeze - especially in Texas!!!
    It is also not going to freeze or otherwise damage itself if you RUN it in cold weather. Like ANY fridge, they don't work well outside of manufacurer expected ambient temps.
    But they nver hurt themselves.
    YOU DO NOT HAVE TO DO ANYTHING TO STORE IT.
    pianotuna
    Regina, SK, Canada
    Posted: 10/05/19 01:05am Link  |  Quote  |  Print  |  Notify Moderator
    Hi wildtoad,
    Have a look here:
    https://forums.goodsamclub.com/index.cfm/fuseaction/thread/tid/24160748.cfm winter camping sticky
    pianotuna
    Regina, SK, Canada
    Posted: 10/05/19 01:07am Link  |  Quote  |  Print  |  Notify Moderator
    No damage from storage, but running them in the cold may kill the cooling unit.
