RV.Net Open Roads Forum: Travel Trailers: Trailer Suspension Questions
 > Trailer Suspension Questions
ktmrfs
Portland, Oregon
Posted: 10/07/19 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
wet bolts and bronze bushings are IMHO a good upgrade if you put very many miles/year on the trailer. It will adress some suspension component weakness. I doubt it helps on keeping things from moving around one bit. I didn't notice any difference. What will help things from moving around is to get the tires balanced, if they are steel wheels make sure the shop uses lug centric adapters. If they are alloy wheels they are probably hub/lug centric. That made a noticeable difference in both my trailers and with several other friends we travel with.
2011 Keystone Outback 295RE
rbpru
North Central Indiana
Posted: 10/09/19 08:51am Link  |  Quote  |  Print  |  Notify Moderator
One cannot deny the advantages of wet bolts and bronze bearings but I would certainly consider shock absorbers.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
Andy F
St Cloud, MN
Posted: 10/09/19 10:18am Link  |  Quote  |  Print  |  Notify Moderator
I finnaly did the wet bolt and rubber ride upgrade and it made a big difference. My 18 year old mechanic/son/wizard did it for me in our driveway. I also now tow a full tank of gray water to add weight over the axles to cut down on bouncing. I may add shocks next year before our next trip west.
Andy
2018 Tiffin Allegro Open Road 36LA
2012 Keystone Bullet 281BHS-Sold
2008 Toyota Sequoia-Sold
ProPride 3P - what a hitch!-Sold
Nights camped in 2017=42
Nights camped in 2018=32
Nights camper in 2019=30
Nights camped in 2020=17
BarneyS
S.E. Lower Michigan
Posted: 10/10/19 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Absolutely it is a job you can do yourself. There is a great thread on this stuck at the top of this forum, complete with lots of pictures, that will help you do it. The former moderator of this TT forum, Les Adams, started it and I and others did their trailers following his lead. I posted about about it also in his thread. I think you will find it very helpful.
Barney
Not towing now.
ken56
Tennessee
Posted: 10/10/19 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
One of the best upgrades a trailer owner can do. The shackles are twice as thick as the factory and the greasable bushings quiet things down 100%. Stability is the biggest advantage from this upgrade. I does not take long for the plastic bushings to wear out. You can do it yourself if you have 2 floor jacks and stands to support the trailer while you take the wheels off and the springs loose.
colliehauler
Mc Pherson KS USA
Posted: 10/10/19 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Getting ready to do a upgrade on my project trailer. I plan to add rubber equalizers, wet bolt kit with bronze bushings, and shocks. I can't say if it's worth the money over stock but it makes me feel better. It's a long winter and I have plenty of time and the cost is minimal. I plan on taking the trailer on a several thousand mile trip to Alaska.
lenr
Indianapolis, IN
Posted: 10/10/19 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
I put the Lippert cushioned equalizer on our second trailer, and couldn't tell the difference. Later we switched to the MORryde SRE4000. Wow what a difference. So, even though the third trailer came with the Dexter cushioned equalizer, we took the new trailer straight from the dealer to the axle shop for SRE4000 and MORryde X-Factor braces on all 3 hanger pairs. I highly recommend the SRE4000 for 5K to 6K axles. MORryde also recommends the X-Factor on the center pair of hangers. You do need 3" of tire clearance above the tires prior to installation of the SRE4000--it will raise your trailer creating an additional 1" of clearance. It needs 4" of clearance to work since it changes shock into movement. I truly believe that the SRE4000 greatly reduces "shaken trailer syndrome". Full disclosure: we also had disk brakes, heavier axles, and wet bolt kit installed at the same time. Our non-RV friends cannot believe we put that much money into a new trailer. We just decided to get it all done immediately when new instead of dribbling it out over a few years.
