RV.Net Open Roads Forum: Tech Issues: run problem with Onan Marquis 5000 BGM
 > run problem with Onan Marquis 5000 BGM
MrWizard
Traveling
Posted: 10/05/19 11:32pm Link  |  Quote  |  Print  |  Notify Moderator
fuel pump approx 6months old - tested pumping good
fuel filter NOT clogged - it is passing fuel, yes enough fuel
yes it has enough oil
it will start , run a few seconds quit
im thinking stuck/bad oil switch
or control board problem
i want to disconnect the oil switch, for testing purposes
but don't know which wire and where
that way i can see if it will run and also Ohm out the switch
thanks
web links and Ideas appreciated
Radiate The Happy
1997 F53 Bounder 36s
MrWizard
Traveling
Posted: 10/06/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Bump
What no wiring diagrams, no pictures, no Sunday afternoon techs
this is desperate
Need battery charging and the A/C
Chris Bryant
Arden, North Carolina
Posted: 10/06/19 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
Try looking around at http://m.flightsystems.com/, particularly the Onan troubleshooting guide, which has an oil pressure switch location section.
-- Chris Bryant
RLS7201
Posted: 10/06/19 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
I believe you oil pressure switch is next to the oil filter. Remove the filter and have a look.
I think the switch is normally open.
[IMG]https://i.imgur.com/lbvsTsAl.jpg "border=0"" border="0" alt="[image]"> [image]Click For Full-Size Image. height=400 width=600[/img]
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
MrWizard
Traveling
Posted: 10/06/19 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for the drawing
i would rather Like get to the other end of the wiring at the control board
draining the oil out of the NON-working generator
so i can take the face panel apart to get at the switch wiring
seems to me as the difficult way to do this
like the putting the cart in front of the donkey
update:
tried again to run the genny
after several trys at starting it using the switch on the Onan, it ran for about 20 seconds, then quit.
now when i push the switch, there is 'thunk' sound as it turns over
this does NOT bode well
* This post was edited 10/07/19 12:25pm by MrWizard *
chuckbear
Posted: 10/07/19 08:59am Link  |  Quote  |  Print  |  Notify Moderator
I had the exact same problem and fixed it with a new carburetor. But with the Onan, it can be a number of things. They are famous for the oil and overheat sensors going bad. The thunk sound when trying to start might be a low battery. Chuck
MrWizard
Traveling
Posted: 10/07/19 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
Was not just a single thunk
It. Was the same sound every time it turned over, every rotation
I'll charge the batteries and try again
bounder39zman
SC
Posted: 10/10/19 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
The early BGM's without electronic governor used a N.O. OP switch.
Later versions used a N.C. OP switch.
On later models, when you energize starter and oil pressure builds up, the governor controller will move throttle rod at carb. to full fuel.
then will stabilize at 1800 rpm when engine starts.
Make sure throttle rod has not become disengaged from actuator (other end of rod from carb).
The "thunk" sound could be many things, It is common for carbon build-up on top of piston and in cyl heads to cause a knocking noise as engine turns over. only fix is to remove heads and clean carbon from heads and pistons. This is actually an ONAN recommended maintenance procedure.
MrWizard
Traveling
Posted: 10/11/19 12:33am Link  |  Quote  |  Print  |  Notify Moderator
thanks for the info
another thing to check
i have purchased a used champion 2000i generator
and using that to power the RVs on board 75amp powermax converter, MW etc..
it won't the A/C compressor, but it will run the blowers and move air around
the compressor surge is just too much for it, with these old A/C units
