RV.Net Open Roads Forum: Fifth-Wheels: Tire Time
 > Tire Time
Cummins12V98
on the road
Posted: 10/07/19 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Me Again wrote:
Or put the Sailun S637's on it, then you have a steel ply carcass tire, which would not require the full 110 lbs on inflation. 90-95 should be fine. Chris
What is the difference between "Steel Ply Carcas" and what GY says about the Endurance construction?
"Carry heavy-duty loads with a redesigned polyester construction reinforced with steel belts."
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
JIMNLIN
Oklahoma
Posted: 10/07/19 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
The Endurance is built just like any fabric carcass P/ST or LT tire with two polyester carcass (body) plies and 1 or 2 nylon caps under the tread plus the usual 2 steel tread belts.
The Sailun S637 has a all steel ply carcass plus the twin steel tread belts. Its intended for regional trailer service work and also rv trailers.
Cummins12V98
on the road
Posted: 10/07/19 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks!
smithrjd
Posted: 10/08/19 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
I am not sure what my rims are rated for, the Maxxis are 80psi. That is what I have been running them at. It orignally had Goodyear Marathons, only D range.. They were replaced with the Maxxis tires before the first real trip. Think I am going with what has worked on the last two 5er's. Another set of Maxxis.
Thanks to All
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 10/08/19 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
What is the difference between "Steel Ply Carcass" and what GY says about the Endurance construction?
Belts are not part of the tire carcass! The Endurance is a poly carcass tire. The Sailun S637 and G614/114 are steel ply carcass tires. Think "sidewall"!
JIMNLIN
Oklahoma
Posted: 10/08/19 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to All
Good plan. You know what to expect from them.
 > Tire Time
