RV.Net Open Roads Forum: Fifth-Wheels: Fifth Wheel Hitch Heigth
 > Fifth Wheel Hitch Heigth
Cummins12V98
on the road
Posted: 10/07/19 09:08am Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
I think what you are saying is that your top of hitch is 4"s below the bed rails. I would guess that most are 2-3 inches lower than rails. Do you have the FW, to hook it up, see if you need to raise hitch higher? The end result should have your FWs under side at least 6"s higher than bed rails. All FW pinboxes are not shaped the same, and can be raised lowered as needed. You'll have to hook er up, then decide best option for your set up.
Jerry
Reading is fundamental!!! You beat me to it!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
