RV.Net Open Roads Forum: Class A Motorhomes: Headlights blinking randomly
 > Headlights blinking randomly
vbrackettjr
Fayetteville, GA
Posted: 10/06/19 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Have a 2003 Holiday Rambler Endeavor. Both headlights will come on for 2 seconds then go out....then blink on & off randomly, every 2 sec to 10 sec. Fuse is in good shape. Owner's manual and Electrical Distribution Panel do not reference a relay for the headlights, so I'm assuming there isn't one. Headlight switch on dashboard is a plunger style. I've wiggled it around (while pulled back) & it doesn't affect the lights blinking on & off. Nor does the high beam lever on steering column affect the blinking. Any advice as to what could be the issue?
K Charles
Connecticut
Posted: 10/06/19 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Do all lights blink or only the head lights?
vbrackettjr
Fayetteville, GA
Posted: 10/06/19 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Only the headlights...and randomly...no predictable pattern.
enblethen
Moses Lake, WA
Posted: 10/06/19 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Headlights are normally on a circuit breaker. My first guess is a filament issue in one of them. Shorted filament could cause tripping of the circuit breaker.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MountainAir05
New Mexico
Posted: 10/09/19 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
Check the alternator voltage.
DrewE
Vermont
Posted: 10/09/19 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
It could be a loose wire or socket or ground connection, too, besides the things already suggested.
fishingbob61
cookevill tn
Posted: 10/09/19 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
On a lot of cars the CB is in the hlight switch.
Bob and Sue
51 years camping
2005 Fleetwood Bounder DP
2004 Chevy. Tahoe
hotjag1
Lake Chelan, Wa/Lake Havasu, Az.
Posted: 10/10/19 12:14am Link  |  Quote  |  Print  |  Notify Moderator
Had a car that did the same thing. Circuit breaker was in the switch. Switch would get hot and lights would go out for a few seconds and then come back on. This scenario kept repeating. Replacing the switch solved the problem.
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
jfkmk
NJ
Posted: 10/10/19 03:47am Link  |  Quote  |  Print  |  Notify Moderator
I had a car that did this and it turned out to be the headlight switch.
hypoxia
Arizona
Posted: 10/10/19 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Daylight Running Light Module (Hamsar?) will also do that when it fails.
Jim
2007 Monaco Signature Noble III ISX 600HP
