RV.Net Open Roads Forum: Tech Issues: How many volts....
 > How many volts....
freewayrandy
'Old Hangtown', Ca
Posted: 10/07/19 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Asking for my neighbor who recently got his first Class A, a used one, when plugged in to shore power, how many volts should we be seeing going to the coach batteries? Assuming there is a trickle charger built in to this unit.
2015 Chevy 2500HD Duramax/Allison, 2018 Grand Design Momentum 328, 2005 Polaris Sportsman 500, 2018 Polaris RZR 900
2oldman
Ca
Posted: 10/07/19 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Depending on the soc of the batteries, anything from 12.7 to 14.1
BFL13
Victoria, BC
Posted: 10/07/19 07:26am Link  |  Quote  |  Print  |  Notify Moderator
The "trickle charger" would be either a converter or an inverter charger. It should put out 13.6 volts approx. unless it is in "boost" at 14.4 approx.
The voltage you see at the battery posts depends on how far up in charge they are at first, but it should rise from there to that charger voltage. Same as in your own RV.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
mbopp
Henrietta, NY, USA
Posted: 10/07/19 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Float voltage on my WFCO converter is 13.2 volts.
2017 Grand Design Imagine 2650RK
2012 F-150 XLT Ecoboost ("EcoBeast") supercab
Just DW & me......
Sam Spade
North Central Florida
Posted: 10/07/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Both those numbers are a bit low.
At 12.7 volts, the batteries will NOT be charging.
IF it is in boost mode, 14.3 to 14.5 is more likely.
IF.....you have a "simple" converter/charger, it might read in the mid 13's all the time.
IF.....you have a multi-stage charger, it likely will start out in the mid 14's and then drop back to the 13's after an hour or two.
IF.....it never goes above 13.0, it likely is not working right.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
CA Traveler
The Western States
Posted: 10/07/19 08:17am Link  |  Quote  |  Print  |  Notify Moderator
13.4V (float) to 14.8V (bulk charge) depending upon the charger and battery SOC. And there is some variation based on battery type if the charger has that option. Plus it will vary if the charger is temperature compensated. It will not drop below the float voltage unless the charger has a standby no charge option.
Or a trickle charger may take a long time to reach the float voltage and above. Or never if there are house or chassis battery loads.
2014 Grand Cherokee Overland
Bob
freewayrandy
'Old Hangtown', Ca
Posted: 10/07/19 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replys and to 'set the stage' for the issue here, he went to the rig for something and when he closed the door the step would not retract all the way back in. Then he heard a clicking from near the steps, apparently from not enough voltage to retract them all the way. I went over and told him we need to check the batteries. The coach batteries, 2 6 volters, 1 was way low on water in all 3 cells the other was way low as well. We topped them off with distilled water then plugged it in to shore power. I checked the terminals with a multimeter and had only about 6.5 volts between the two. I thought there would have been at least 12 volts. Another issue here? Perhaps the batts. are toast?
CA Traveler
The Western States
Posted: 10/07/19 08:24am Link  |  Quote  |  Print  |  Notify Moderator
The typical RV does not have a trickle charger. Instead the charger is/should be a 3+ stage charger - float, absorb, bulk.
2oldman
Ca
Posted: 10/07/19 08:26am Link  |  Quote  |  Print  |  Notify Moderator
Yep. Not unusual for a used rig.
BFL13
Victoria, BC
Posted: 10/07/19 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Do the steps on a Class A operate from the house or engine battery?
