RV.Net Open Roads Forum: Tech Issues: Blow-by Yamaha ef3000ise
 > Blow-by Yamaha ef3000ise
keithahl
canada
Posted: 10/07/19 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Sigh...went to check the air filter on my yammy generator and found the filter soaked in oil. Maybe a hint of gas as well.
She has about 500 hours on it (the genset, not the filter)
Well taken care of, all the maintenance done on time, good gas etc.
No leaks or drips in the case.
Should I have expected less life than more on this thing? I was hoping for 2 or 3 thousand hours.
Rings?
Anybody ever pull one of these apart and hone out the cylinder and replace the rings?
Maybe its something else?
Thanks for any insights.
* This post was edited 10/07/19 10:14am by keithahl *
ScottG
Bothell Wa.
Posted: 10/07/19 10:36am Link  |  Quote  |  Print  |  Notify Moderator
All maint? Have you done the 300 hour valve adjustment?
Scott
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
keithahl
canada
Posted: 10/07/19 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Hey Scott, I did! Which was an adventure...long story.
Would out of spec valve lash create blow-by?
(not a mechanic nor even remotely inclined this way...just too broke to pay one to do things for me)
ScottG
Bothell Wa.
Posted: 10/07/19 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not really sure. It seems like it's possible if a valve isn't totally seating that some backwards flow could occure. Especially since you say it has the odor of fuel. And you've probably seen where gas dries up and leaves an oily residue behind.
Just a shot in the dark!
S
keithahl
canada
Posted: 10/07/19 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
I like shots in the dark that do not involve me having to gut this thing and hopefully do the ring job correctly AND get it back together in a timely manner.
Or I suppose I could run it to death and finally just bite the bullet and get an 1800 rpm diesel...that will outlive me by a few decades.
K Charles
Connecticut
Posted: 10/07/19 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
If valve clearance is too tight, intake opens too soon and that's what you get.
Chum lee
Albuquerque, NM
Posted: 10/07/19 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
"Sigh...went to check the air filter on my yammy generator and found the filter soaked in oil"
I wouldn't call that soaked in oil. If it was "soaked in oil" there would be oil dripping off the filter. A few drops will do that. How is the genny running? Oil consumption? Excessive smoke? Hard starting? Making rated power? If everything is OK I think you are over reacting.
Do ALL the required maintenance and see what happens.
Chum lee
ScottG
Bothell Wa.
Posted: 10/07/19 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
You might want to check the valve clearance just for good measure. If it's too tight you can end up with burned valves.
keithahl
canada
K Charles: I'll check the clearance and see what's what. Cheers.
Chum Lee: Fair enough, but still pretty oily. I can squeeze it out from the paper filters foam edge. (not the sleeve, but the foam attached to the filter edges that seat against the housing). When I run a towel into the filter grooves it comes out oily. Not sure if that is the way it should be or not. Overreacting?...possibly. All I know is it had never done this prior. She is running fine, no smoke, or at least none that makes me worry. It starts fine, the output is fine.
You know you are blowing my chances of convincing my wife we should have this:
http://www.centralmainediesel.com/order/Perkins-6-kW-Diesel-Generator.asp?page=P6125
I'll get another filter and see.
ScottG
Bothell Wa.
Posted: 10/07/19 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
Trying to figure out in my mind how blow-bye could even get there. Seems like when it's running, blow bye would be pulled in and burned.
I wonder if it's just some minor, left over vapors that escape after hot shutdown.
I should check the air filter on my Honda.
