RV.Net Open Roads Forum: Tech Issues: Shaw Direct/Winegard
 > Shaw Direct/Winegard
MDKMDK
Canada
Posted: 10/08/19 07:04am Link  |  Quote  |  Print  |  Notify Moderator
It was my understanding that the newer G1 satellite, which is supposed to carry most of the HD stuff now, casts a more northerly coverage shadow, than the old Anik F1/F2 birds. ShawD customers have been reporting that they can still receive programming south of the 49th, but that it's inconsistent.
Anecdotally, I was shopping for a portable dish receiver system a few years back and was told by Winegard, that the Trav'ler full sized roof mounted dish would probably be the best bet to pick up anything in the US, going forward. They said the domed portable systems "paddle" dishes were probably too small to be effective in picking up signal.
Maybe some ShawD customers in the deep south will add an update of where they are (approximately?) and what dish/systems they're using?
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
campinghut
Carstairs Alberta
Posted: 10/08/19 07:20am Link  |  Quote  |  Print  |  Notify Moderator
As to the upgrade the winegard part number is sk-73up
Tim And Bev
2018 Mobile Suites 38RSSA, 560w solar, 2800w inverter (3 previous Artic fox trailers, 1 Cedar Creek, 1 Heartland Cyclone. In the last 8 Years)
2019 F350 (Previous trucks 2006, 2008, 2012, 2015, 2017 all Ford F350's)
Bill.Satellite
Full-timer
Posted: 10/09/19 05:11am Link  |  Quote  |  Print  |  Notify Moderator
Winegard was being generous with their description of service with ShawD and a dome. First, you would have to buy a dome for ShawD as the standard domes will not work. 2nd, the domes will not receive any programming outside of Canada or the extreme N. parts of the US.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
jheppner
Scotch Creek, B.C. Canada
Posted: 10/19/19 10:59am Link  |  Quote  |  Print  |  Notify Moderator
We have had the Winegard updated software installed in our dish for Shaw Direct. It worked fine all the way to Laughlin where it decided it couldn't find both satellites so it stowed. I called Winegard and they said when it honed in on "111" I should push the power and select buttons at the same time to lock the dish in. They said DO NOT pull the plug as you will have to have the controller totally re-set. I've been following their instructions and it works fine although I object to paying approximately $500 for software that doesn't do what it was supposed to. At this point, we're not having any problems getting the HD channels although they have a tendency to go missing and then return again. Very puzzling.
West & above Bishop, California
Posted: 10/28/19 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Down Mexico way?
jheppner
Posted: 10/30/19 11:16am Link  |  Quote  |  Print  |  Notify Moderator
We're now in Parker, Arizona, and the Winegard/Shaw Direct is still not operating on "automatic" but at least we can get a signal even though there are still some channels missing. I'm not going to call Shaw Direct about this because then I might have to explain where I am.
Bill.Satellite
Full-timer
Posted: 10/30/19 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
It's not working after you did the $600 required update?
jheppner
Posted: 10/31/19 10:46am Link  |  Quote  |  Print  |  Notify Moderator
No, it definitely is not working after paying for the updated software. See my post of October 19 where I've reported Winegard's solution. I've been meaning to call them to get further info but right now I'm in a bad area for cell phone reception.
Bill.Satellite
Full-timer
Posted: 10/31/19 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
That really sucks. Please keep update once you get in touch with Winegard.
joebedford
Sheltering at home
Posted: 10/31/19 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Just curious: you didn't state the vintage of your Travel'r. Do you have the xKU triple LNB?
