RV.Net Open Roads Forum: General RVing Issues: Freshwater Hookup Port Question
 > Freshwater Hookup Port Question
the e-man
Virginia
Posted: 10/07/19 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Hi All,
After getting a new camper last spring, I had to think of a different way to hook up my freshwater hose. The new camper had a universal docking station. That meant I had to run a hose up through a port in the RV floor to hook it up inside a storage compartment. I couldn't seem to get the hose tight enough and had a drip. I think I have solved that. I used one of the flexible hose couplings that come with a water filter and put that in between the hookup and the hose. I also added a few other things like a quick connect and a better water hose. I did a writeup of all the parts I use to hookup my freshwater hose at drinking water hose connections
Wondering what people do to plug the port in the floor. I would prefer not to have mice, ants or other pests come into the camper through that hole. So far, I have just been stuffing a rag in around the hose. Anyone have a better solution?
Thanks
2018 Grand Design Transcend 28MKS
2010 Ram 2500
Travel Trail Sail - Info on Travel Planning, RV Camping, Outdoor Living
Yosemite Sam1
Under the pines.
Posted: 10/07/19 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
Steel wool will be a better plug than rag that a mice can still gnaw through -- assuming your flooring is not wood, thin plastic, etc .
K Charles
Connecticut
Posted: 10/07/19 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
I put a 90 degree elbow on before the hose. The hose fills the hole quite nicely.
schlep1967
Harrisburg, PA
Posted: 10/07/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
+1 Brass 90 degree elbow. Also make sure you replace the rubber washer every now and then.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
bob213
Fresno, CA
Posted: 10/07/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Replace existing port with a deck plate thru floor that you can cover when not in use. Small one just for hose.
deck plate
the e-man
Virginia
Posted: 10/07/19 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the answers so far.
Bob213 said "Replace existing port with a deck plate thru floor that you can cover when not in use." I appreciate the idea.
Just to clarify, the port has a flip up plate that covers the hole when not in use. When I put anything through the port - like a hose or cable tv cord - the plate is in the open position and there is a significant gap around the hose & cable. It seems like a bad idea to have an open hole in the floor leading into the storage compartment.
Thanks Yosemite Sam1 for the steel wool idea. Sounds promising.
Any additional recommendations?
DutchmenSport
Indiana
Posted: 10/07/19 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
Or, just fill your fresh water tank, disconnect the hose, close up the hole, and pump the water from your tank, no pressure regulators needed, no critters, bugs, or problems, and it also makes you keenly aware of how much water you are using.
2chiefsRus
USA Somewhere
Posted: 10/08/19 05:03am Link  |  Quote  |  Print  |  Notify Moderator
we use a heavy duty sponge for tile grouting. Cut it to shape of the hole with a slit cut into the inside hole for the hose.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
momentum rv
Central Cal.
Posted: 10/08/19 08:23am Link  |  Quote  |  Print  |  Notify Moderator
x2 works great!
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
schlep1967
Harrisburg, PA
Posted: 10/08/19 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Switch out your hatch for one of These.
