RV.Net Open Roads Forum: Fifth-Wheels: Need help with sulphur smelling water
 > Need help with sulphur smelling water
Jetstreamer
Milwaukee, Wisconsin
Posted: 10/08/19 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
Isn’t the sulfur smell a product of iron content in the water?
I have an iron filter on my well system and without it I have sulfur smelling water...
agesilaus
North Florida
Posted: 10/08/19 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
The only thing I can suggest that would be cheap is to buy a aquarium air pump, a cheap one. With an air stone and some tubing. You can put that in the bottom of a container to speed up the aeration process.
But there is no cheap way to treat a pressurized system that I know of. It would require a flowmeter, computerized metering pump, and a sensor feedback system for H2S. Each one of those components would probably be well over a thousand dollars plus you'd have to get the training to operate them since they are not simple.
I can imagine a cheap system to degas water before using it to fill your water tank. Batch treatment in other words. But that would require lots of operator time. And some tankage outside the camper. You'd duplicate the system I describe above used to process drinking water.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
agesilaus
North Florida
Posted: 10/08/19 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
No, Sulfur is Sulfur a yellow solid and Iron is that metal we all know. Iron Reducing bacteria and sulfate reducing bacteria will produce Hydrogen Sulfide as a byproduct of eating iron and yes then there will also be iron dissolved in the water. These are anaerobic bacteria and can only live in the absence of oxygen. Some people think they are the remnants of ancient life here on earth before the atmosphere was filled with oxygen. No they are forced into tiny biomes where there is no O2. Like underneath corrosion (aka rust) layers.
The situation is more complicated than I describe above but I tried to simplify it.
hippiemade
Oregon
Posted: 10/08/19 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
Yes I think so I have a whole house system- but obviously not a powerful enough one
hippiemade
Oregon
Posted: 10/08/19 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you
azdryheat
Tucson, AZ
Posted: 10/08/19 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
I had the sulfur smell. Changed the water heater anode and gave the water heater a good flush. No more sulfur smell.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
keymastr
S.E. Washington
Posted: 10/08/19 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
If you use the fresh water tank on the trailer you could simply use a fairly large aquarium pump to aerate the water and the excess air could escape out the vent. Not sure how long it would take but it would be your cheapest solution. You could leave the filler cap off for better air evacuation.
wildtoad
Blythewood, SC
Posted: 10/09/19 05:29am Link  |  Quote  |  Print  |  Notify Moderator
This is where I’d start. If your WH in the fifth wheel has an anode rod (Suburban?) I’d try a new one. While it’s out, give the WH a good flush. If you fifth wheel sits a long time between use drain the WH.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
agesilaus
North Florida
Posted: 10/09/19 05:36am Link  |  Quote  |  Print  |  Notify Moderator
That's a good idea, tho I'd give the water heater fix a try first
Roger10378
Goodrich, MI.
Posted: 10/09/19 06:18am Link  |  Quote  |  Print  |  Notify Moderator
In our area we have this problem. The man at the plumbing store said just remove the anode from the water heater. It has been smell free now for almost 30 years. I have also heard that a Zinc anode will eliminate the smell while still giving you the protection of a anode.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
