RV.Net Open Roads Forum: Class A Motorhomes: inside lights dim
str8shooter_mn
Minnesota
Posted: 10/08/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
I just replaced the coach batteries, 2-6v deep cycle. We are plugged into shore power. After a while our inside lights get very dim. Disconnected converter and checked out put. It is at 13.62 VDC as manual says it should be. Lights get bright again after starting coach. Running off of alternator Voltage.
What am I missing? Is there a relay somewhere that is supposed to switch from alternator to converter power to charge batteries when coach is turned off? Old batteries were shot, wouldn't take a charge.
DFord
Near St Louis, MO
Posted: 10/08/19 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
It would be most helpful if you show the year and model of your MH. Without any of that, any answer you'd get would be a guess.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
enblethen
Moses Lake, WA
Posted: 10/08/19 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Many Class As have a charge relay that enrgizes when the coach is running. This is to charge batteries.
Do you have an inverter/charger or a converter? Make and model?
You could have a loose connection causing lower then normal voltage from the batteries and the inverter/charger or converter.
Make and model would be beneficial!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
str8shooter_mn
Minnesota
Posted: 10/08/19 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Coach is a 2011 Fleetwood bounder classic 36R on a workhorse chassis. Has a converter WFCO WF-9800 series, 65 AMP
* This post was edited 10/08/19 08:54pm by str8shooter_mn *
ScottG
Bothell Wa.
Posted: 10/08/19 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Absolute classic sign of a dying converter.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Flute Man
Payson, Arizona
Posted: 10/08/19 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
With everything hooked up like before with the lights dim I would make that same voltage test. Please let us know what the results of that voltage test are.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
ArchHoagland
Clovis, CA, USA
Posted: 10/09/19 02:00am Link  |  Quote  |  Print  |  Notify Moderator
Was it working OK before you changed the batteries?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Ivylog
Blairsville, GA and WPB, FL.
Posted: 10/09/19 04:28am Link  |  Quote  |  Print  |  Notify Moderator
Dim lights = low voltage = charger/converter not charging. No load voltage of the converter doesn’t tell you much...what’s the voltage when hooked to the batteries?
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
str8shooter_mn
Minnesota
Posted: 10/09/19 05:40am Link  |  Quote  |  Print  |  Notify Moderator
Voltage before changing batteries was 11.3 volts after 3 hour charge at 10 amps. Batteries were disconnected during charge.
Voltage of batteries after replacement was 12.5 VDC with converter connected
dougrainer
Carrolton, Texas
Posted: 10/09/19 06:01am Link  |  Quote  |  Print  |  Notify Moderator
Either the Converter is bad or there is a fault in the charge wiring from the Converter to the batteries. Doug
