RV.Net Open Roads Forum: Class A Motorhomes: inside lights dim
cavie
Posted: 10/09/19 06:14am Link  |  Quote  |  Print  |  Notify Moderator
You changed the batteries.
That's the place I would start. There are 2 30/40 amp reverse polarity fuses on the converter. There may be an in-line re-setable fuse near the batteries.
cavie
Posted: 10/09/19 06:16am Link  |  Quote  |  Print  |  Notify Moderator
cavie
str8shooter_mn
Minnesota
Posted: 10/09/19 07:53am Link  |  Quote  |  Print  |  Notify Moderator
Thank You all for your input. After further investigation, find that the converter is faulty. Have new one ordered via amazon.
DutchmenSport
Indiana
Posted: 10/09/19 11:13am Link  |  Quote  |  Print  |  Notify Moderator
I had something similar happen to my 5er a couple months ago. Lights got dimmer and dimmer and dimmer. Everything checked out just fine. Couldn't figure it out. What I failed to do after we returned home from the week-end trip when this happened was .... well.... (do I really have to admit this ... well OK, if it will help you) ... I forgot to flip the breaker on at my RV electric box!
The residential refrigerator was running of the inverter for quite a while, drawing down the battery, making lights go dim after a few hours. DUH!
Check to make sure you flipped the breaker back on at your power pole! It might be just that simple.
