RV.Net Open Roads Forum: Tech Issues: 50 amp coach on 30 amp power
 > 50 amp coach on 30 amp power
Grey Mountain
On the rez somewhere in Indian Country
Posted: 10/09/19 07:20am Link  |  Quote  |  Print  |  Notify Moderator
We are currently in a 30amp site. As we use various electrical components, the "brain" will show us how many amps are being used. What happens if we exceed the 30 amps available? Say, two small heaters that will use 15 amps each all by themselves. The fridge, of course, is always on and pulls a few amps.
We are very inexperienced in using 30amp only in this coach, although our former gasser was a 30 amp rig.
Thanks.
GM
2006 Discovery 39S Tin Teepee
Honda CR-V Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
2oldman
New Mexico
Posted: 10/09/19 07:26am Link  |  Quote  |  Print  |  Notify Moderator
I don't know, but why don't you use the furnace?
Sam Spade
North Central Florida
Posted: 10/09/19 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Several things can happen.
IF....you have the adapter at or near to the supply pole, nothing bad should happen to the RV equipment.
BUT.....
The adapter might overheat.
The 30 amp receptacle might overheat.
The 30 amp breaker at the supply outlet might trip.
It is really NOT good to exceed a 25 amp draw on a 30 amp service because you don't know how good the feed really is.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
fj12ryder
Platte City, MO
Posted: 10/09/19 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Probably because electricity to run the heaters is included in the cost of the site, but propane costs extra. That's why I do it.
If you exceed the 30 amps, then the circuit breaker on the pedestal should trip.
Howard and Peggy
"Don't Panic"
accsys
Green Cove Springs, FL
Posted: 10/09/19 07:33am Link  |  Quote  |  Print  |  Notify Moderator
If you exceed the 30 amps the circuit breaker on the pedestal should pop and shut off power to the coach. If we are on a 30 amp site we switch the water heater to propane only, set the inverter/charger to only use 5 amps to charge the batteries, and set the reefer to propane only (if it's an absorption type). This will allow more power to be used on other items without popping the breaker on the pedestal. Our air conditioners are also heat pumps and we have found them to be the most efficient way to heat the unit as long as outside temps are above 40°. If below 40°, we use the furnace(s) which use very little electricity. Electric heaters are about the most inefficient way you can heat a coach.
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350 (Mothership)
2004 Liberty Renegade 4x4 Toad (Libby)
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
rhagfo
Portland, OR
Posted: 10/09/19 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Well depending out side temps you could get by with one heater, or just use your furnace.
That said if you excede 30 amps you will likely trip either the the Post breaker, or the main in your coach.
swphotobug
varous
Posted: 10/09/19 07:54am Link  |  Quote  |  Print  |  Notify Moderator
You don't say what coach you have. Ours is a 50a that runs fine on 30a. We have a system that sheds loads as other components need electricity. An example is the A/C's. Only one will run at a time when shedding. Our coach is a 2015, if yours is newish check to make sure you don't have load shedding. Other than that you will quickly learn what combination trips the breaker. We have all our electic items labeled with how much each takes. We bought a Kill-A-Watt and measured everything.
Cummins12V98
on the road
Posted: 10/09/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
"YOU" choose what you use by watching amps used for each item on your meter. Don't exceed 30A and all is well.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
BB_TX
McKinney, Texas
Posted: 10/09/19 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Simple answer is it will trip the park breaker but will not harm anything. Just reset the breaker and remember what you were using at the time and don’t use that combination any more.
time2roll
Posted: 10/09/19 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Heater is probably 12 amps not 15. I agree it would help to run what you can on propane or you could be in the dark. If you do choose to run near the max keep an eye on the 50/30 adapter as they are known to overheat if the connection is less than perfect.
675w Solar pictures back up
