RV.Net Open Roads Forum: Class A Motorhomes: Electrical issue
pamo
branson missouri
Posted: 10/09/19 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Have 2006 Fleetwood excursion. First trip and everything seemed to be working ok. Now the right side and front tv and bedroom tv have now power. Seems like circuits are not working. Checked breakers and all seemed to be good. Any ideas?
navigator2346
texas
Posted: 10/09/19 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Check for a tripped GFI and check for a tripped breaker on the inverter
Big Katuna
Deland, FL
Posted: 10/09/19 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Check the breakers on the inverter.
Check the GFI on that side.
My Kharma ran over my Dogma.
2chiefsRus
USA Somewhere
Posted: 10/09/19 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
check gfi in bathroom and kitchen and maybe under table
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
craig7h
Branson MO area
Posted: 10/10/19 03:34am Link  |  Quote  |  Print  |  Notify Moderator
With everybody else it sounds like a bad or tripped GFI outlet. Let us know what you find.
Itasca Meridian SE 36g
Road Master Tow Dolly
mrmichael80
Posted: 10/10/19 04:49am Link  |  Quote  |  Print  |  Notify Moderator
FYI. Tvs will usually not be on if engine is running
eHoefler
ozark mountains
Posted: 10/10/19 06:00am Link  |  Quote  |  Print  |  Notify Moderator
Try it on the generator, you could have a leg down on the 50 amp at the pedestal.
2019 Ram Limited, 3500, Crew Cab, 1000FTPD of Torgue!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
tinkerer
Wisconsin
Posted: 10/10/19 06:10am Link  |  Quote  |  Print  |  Notify Moderator
I vote for the breaker buttons on the inverter. I had the same issue with my 2007 Discovery and it took me while to figure it out.
janstey58
Glenwood, IA
Posted: 10/10/19 11:09am Link  |  Quote  |  Print  |  Notify Moderator
TV are on your inverter, so likely that is the issue if other breakers are ok.
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
Executive
Posted: 10/10/19 11:43am Link  |  Quote  |  Print  |  Notify Moderator
FYI the 'breakers' on the inverter are different than ones you find in your electrical panel. They are usually button breakers. These are very small and easily missed. Look for a button about 1/8" in diameter. Push it in and see if that works....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
