RV.Net Open Roads Forum: Class A Motorhomes: Replacing Thethrod toilet with Dometic
 > Replacing Thethrod toilet with Dometic
two travelers
Smithtown, NY
Posted: 10/09/19 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Replacing existing Therford toilet with a Dometic. Parts supplier says I need a mounting kit for this which, according to the description converts 4 bolts to 2 needed for the Dometic. Has any one done this replacement project? Do I need this $45 plate? Utube videos seem to show a direct drop in replacement.
Thanks to all who share their knowledge.
ferndaleflyer
everywhere
Posted: 10/09/19 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
I did mine and the flange looked just like the ones in the house and I didn't buy an adapter. Take your old one off and look, worst thing that could happen is you are at Lowes or Home Depot buying a flange. This was just this summer. It did not line up square so I loosened the big clamp and twisted it straight. took about 1/2 hour.
accsys
Green Cove Springs, FL
Posted: 10/10/19 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Our Thetford Elite only has two bolts.....??
John & Doris
Doris and Robbies Blogs
2007 Tiffin Phaeton QDH 40 w/Cat 7 350 (Mothership)
2004 Liberty Renegade 4x4 Toad (Libby)
Roadmaster Falcon 2 tow bar
Air Force One toad braking system
FMCA F380583, PA, Good Sams
Ed_Gee
Central Oregon coast
Posted: 10/10/19 10:32am Link  |  Quote  |  Print  |  Notify Moderator
Yeah....ours, too.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
crawford
Dandridge Tenn.
Posted: 10/10/19 11:18am Link  |  Quote  |  Print  |  Notify Moderator
My plate on floor takes two or four still I see no problem.
Change from a c class to a A class Georgetown 07 triple slide
Wherever I happen to park
Posted: 10/10/19 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
I went the other way.. No difference in the flange. No adapt-a-kit needed with one small exception
The Fresh water side the hookup is different... How I modified mine
Added a shut off valve (1/2 inch IPT to compression fitting)
Used a flex hose (1/2 inch one end. Compression fitting the other matching valve)
now I can shut off the water to the toilet without shuting off entire RV if there is a problem (Yippie)
Home is where I park it.
Edd505
Elephant Butte, NM
Posted: 10/10/19 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
I just did this last month. The Dometic 310 fit right on the flange the Therford had been on. You'll love the Dometic, uses a bit more water but water in the black tanks your friend. While you have the toilet out, put a shark bite shut off it the supply line. My Therford went TU on a weekend so I had to shut water off to the entire 5W. Won't happen again with the shut off.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
