RV.Net Open Roads Forum: Tech Issues: Urgent Need of Advice re Winterizing!
 > Urgent Need of Advice re Winterizing!
MFL
Midwest
Posted: 10/10/19 11:36am Link  |  Quote  |  Print  |  Notify Moderator
allen8106 wrote:
MFL wrote:
If you blow everything out, and run the pump dry, you should be okay inside a barn. Big difference between temp of 25, and 10. I am thinking inside the barn should stay considerably warmer than out door temp. An electric heater inside should protect pipes. If you are sure of the small amount in tanks, they should survive too, as long as you are in the barn.
This is just an opinion, don't call me if everything freezes solid. [emoticon]
Jerry
Not sure where you got the idea he was in a barn!!
"I will be running a small electric heater inside the unit which should help keep the temp inside above freezing, and the TT will be parked inside a barn out of the wind."
Reading comprehension starts by reading entire OP
Jerry
djousma
SW Michigan
Posted: 10/10/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
make sure you have enough propane to keep the trailer warm. 4 days of cold like that you will burn a bunch of it!
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
allen8106
Burrton. KS
Posted: 10/11/19 11:21am Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
Jerry
You are correct, sorry. I missed that!
Jerry
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 20
Harvey51
Alberta
Posted: 10/11/19 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
On our first trip we discovered that at -10C, 15F, the only part that froze was the freshwater drain tap. I put a mitt over it and all was well in the morning. Nice to know we are okay down to -10 without winterizing. We had -7 last night here in Alberta.
Using the pump to pull pink antifreeze its good down to -40. I pour some pink stuff down the sinks and toilet to protect the traps, tanks and drain valves.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
