RV.Net Open Roads Forum: Tech Issues: Urgent Need of Advice re Winterizing!
 > Urgent Need of Advice re Winterizing!
DFord
Near St Louis, MO
Posted: 10/09/19 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Light bulbs / spot lights inside the sink cabinets and shining on the holding tanks will help. After a few hours, open the cabinet doors/drawers and see if the lights are doing any better than you small heater. 1/4 cup of rock salt in the shower drain and the others if they aren't removed like was suggested.
Lot's of luck!!
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
MDKMDK
Canada
Posted: 10/09/19 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, a little cold weather plus a winterizing "emergency" sure gets the keyboards a hummin' on here.[emoticon]
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
cooldavidt
Vancouver
Posted: 10/09/19 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
All sounds good.
Blow thru your fresh water (25psi) thru open valves.
Leave all valves open.
Water in the tanks is not a problem but it would be better to open the valve
Don’t forget the outside shower.
Dave H M
IL
Posted: 10/10/19 05:48am Link  |  Quote  |  Print  |  Notify Moderator
It was the black tank flush that was my demise. [emoticon]
ndrorder
Southwest
Posted: 10/10/19 06:22am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone mentioned draining the hot water heater. Blowing pipes isn't enough to drain some water heaters.
__________________________________________________
Cliff
2011 Four Winds Chateau 23U
Wherever I happen to park
Posted: 10/10/19 06:51am Link  |  Quote  |  Print  |  Notify Moderator
1: water pump
on the inlet side of the water pump is a strainer. Lay a towel on the floor below it and open the case. Drain the water out of it and run the pump for like a minute to clear the lines. Then blow again. (Do this after the 1st or second of like 10 blows to get all water out)
2 Toliet. Flush wile blowing to insure that line is clear
3[emoticon]e black/gray water.. If less than 5 gallons can you bucket carry to a toilet?
Home is where I park it.
Terryallan
Foothills NC
Posted: 10/10/19 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Thinking out loud here. I learned in school that freezing water expands and bursts pipes. however IF it has some where to expand to. It will not burst the pipe. So if the black, fresh, or grey tanks are not full. The water has room to expand. Even the water in the drain pipes has room to expand back into the tank.
I leave 5 gal or so in my black tank year round. And yes it does get cold here, sometimes in the single digits.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
ScottG
Bothell Wa.
Posted: 10/10/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Ah for cripes sakes. I winterized this week and totally forgot about the danged outside shower.
Nearly 30 years of RVing and I finally did it.
Thanks for the reminder!
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
schlep1967
Harrisburg, PA
Posted: 10/10/19 10:25am Link  |  Quote  |  Print  |  Notify Moderator
Your on a ranch. Got any Hay or straw bales? Stack them up around the bottom of the RV all the way around to block out as much air as possible. Before you put the last one in Hang a trouble light from the frame near the tanks. Should keep it warm enough under there to keep the tanks from freezing. Empty and bypass the water heater, blow out the lines and/or add antifreeze to the system.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
allen8106
Burrton. KS
Posted: 10/10/19 10:55am Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
If you blow everything out, and run the pump dry, you should be okay inside a barn. Big difference between temp of 25, and 10. I am thinking inside the barn should stay considerably warmer than out door temp. An electric heater inside should protect pipes. If you are sure of the small amount in tanks, they should survive too, as long as you are in the barn.
This is just an opinion, don't call me if everything freezes solid. [emoticon]
Jerry
Not sure where you got the idea he was in a barn!!
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 36
