RV.Net Open Roads Forum: Class A Motorhomes: RVs and California's Planned Power Outages
 > RVs and California's Planned Power Outages
Page of 8
4x4van
California
Posted: 11/07/19 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Dutch_12078 wrote:
I was told by an Asplundh tree trimming supervisor the standard used by most power companies is 18 feet, not 18 inches. Asplundh is a line clearance contractor that works for many power companies in the US, Canada, Australia, and New Zealand.
In CA, General Order 95 (GO-95) states that radial clearances of bare line conductors up to 22.5kV (22,500 volts) from tree branches or foliage is 18" (I'm looking at the GO-95 specs as I type this; Table 1, case 13). Higher voltages are typically Transmission, and are usually on very tall poles/towers, and as such are not normally an issue for tree clearance. As Dutch said, those clearances are based on a formula rather than a fixed number, and are more based on clearances between the lines themselves rather than between the lines and vegetation.
I am not as familiar with the rest of the country, since they go by NESC rather than CA's GO-95, but generally speaking, GO-95 is usually even stricter than NESC. In a cursory search, I can find no reference to clearances from trees in the current NESC.
* This post was edited 11/07/19 03:10pm by 4x4van *
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
MRUSA
Wellington, FL
Posted: 11/07/19 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Living in Florida, we use our RV as an emergency venue in case of hurricanes. We keep the waste tanks empty, water and fuel tanks full so we can live in it in all its self contained glory. Saved us from installing a home generator as many neighbors have done at a cost of tens of thousands of dollars. There have been times when we lost power for up to 4 days and we were completely comfortable in the RV. Of course it could be longer. We can dry camp for at least 10 days before we would have to find dump and fill facilities.
Marc, Wellington FL
2013 Entegra Anthem 44SL
2018 Lincoln MKX toad
EEZ-RV tire pressure monitor
Page of 8
