RV.Net Open Roads Forum: Beginning RVing: Exercising generator and A/C after winterizing question?
 > Exercising generator and A/C after winterizing question?
Golferdude21
Illinois
Posted: 10/10/19 06:21am Link  |  Quote  |  Print  |  Notify Moderator
I just had my travel trailer winterized for the winter. I want to exercise the generator one more time before it goes into storage for winter....and by doing this, i will need to put a good electric load on it. Am I able to run the A/C without affecting any of the winterization I just had done?? Might be a stupid question, but i know the A/C has condensation and water that builds up and runs off the camper. Just didn't know if it affected any pipes or anything inside the camper.
Thanks in Advance
Dutch_12078
Winters south, summers north
Posted: 10/10/19 06:26am Link  |  Quote  |  Print  |  Notify Moderator
Running the A/C will not hurt any of the plumbing since there's no connection between them. If the humidity is low enough, there may not be any significant condensation anyway.
Dutch
2001 GBM Landau 34' Class A
way2roll
Wilmington NC
Posted: 10/10/19 06:55am Link  |  Quote  |  Print  |  Notify Moderator
No harm running the AC, but Gen sets should be exercised monthly not just once before storage.
Wherever I happen to park
Posted: 10/10/19 06:57am Link  |  Quote  |  Print  |  Notify Moderator
Running the A/C won't hurt the thing or affect winterizing since winterizing an AC amounts to cleaning the filters.
HOWEVER DO NOT RUN A/C IF BELOW FREEZING OUT.
Space heaters. on low.. up to 4 (depending on generator) each on a seperate breaker.. That works
Space heaters (2) on high may work however they may also damage the outlets. Have seen 3 so far (one in my own rv) damaged by a space heater load
Now have special outlets in my RV for those (15/20 amp, 12 ga wire bent around a screw, not punch down and one outlet to a breaker)
Home is where I park it.
Golferdude21
Illinois
Posted: 10/10/19 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Jeeze I didnt realize this. I always used to just use the propane heater to heat until last weekend when i read that most people use a space heater when on shore power to save propane. So i used a small1 on high so 1500watts and worked good. Didnt think that ud have outlet problems frim wiring w just one....WOW. We had it goin overnight too...??
Golferdude21
Illinois
Posted: 10/10/19 07:28am Link  |  Quote  |  Print  |  Notify Moderator
I guess i should probably take that outlet off to make sure no wires are messed up huh?
JimK-NY
NY
Posted: 10/10/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
You want to warm up the generator, drive out the moisture. You do not need to put on a load, just let the generator run 15 minutes or so.
Bionic Man
Colorado
Posted: 10/10/19 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Maybe it depends on your trailer, but I’ve run a space heater on high for years on mine without issue.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
opnspaces
San Diego Ca
Posted: 10/10/19 08:48am Link  |  Quote  |  Print  |  Notify Moderator
With the way these RV's are thrown together I don't doubt that from time to time an outlet has been installed with the wiring not inserted correctly. But that of course does not mean that every outlet is installed incorrectly and therefore a problem. I have run a 1500 watt space heater in my trailer for many years with no problems and I will continue to do so. If you're really concerned you would have to unplug or turn off the generator and pull the outlet out of the wall to inspect. See if there are signs of heat damage like burnt or discolored wire insulation or melting in the plastic near the wire contact points. If no damage push the outlet back into the wall and don't worry about it.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Posted: 10/10/19 09:33am Link  |  Quote  |  Print  |  Notify Moderator
Golferdude, you could use a little time learning the concepts of your camper systems. Will help you down the road. (Literally and figuratively).
Why do you need to “exercise” the genny 1 more time?
Is it propane? Then no worry about bad gas.
Just change the oil? If not maybe you should, not really pertinent to this discussion though. But a reason to warm it up.
Gas stability? This is real if it’s gasoline powered. Stabilize some fresh fuel or throw some Av gas in it for the winter and run it.
