RV.Net Open Roads Forum: Beginning RVing: Exercising generator and A/C after winterizing question?
 > Exercising generator and A/C after winterizing question?
Sandia Man
Rio Rancho, NM
Posted: 10/10/19 09:42am Link  |  Quote  |  Print  |  Notify Moderator
We use a portable electric space heater for exercising our Onan since it is primarily performed during the camping off season. Both of our gennies are actively utilized during the RVing season since we do more boondocking and dry camping than anything else. No issues on prolonged use of space heaters thus far, sometimes we have 2 of them cranking although both are rarely set to high at the same time.
Golferdude21
Illinois
Posted: 10/10/19 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Its a gas Onan onboard genny. Havent ran it in a few months figured before it goes indoors and away from me for 5 months i should run it
Boon Docker
Posted: 10/10/19 10:58am Link  |  Quote  |  Print  |  Notify Moderator
My 6 year old Champion 2000 sits idle for 6 months through the winter with no exercise. I put in fresh gas in the spring and start it with one pull.
Posted: 10/10/19 11:15am Link  |  Quote  |  Print  |  Notify Moderator
Yup, agree then. But either run it out of gas, or put some fresh gas with stabilizer in an empty tank and run that or some no. Ethanol with stabilizer.
Gummed up carbs are a real and common occurrence and it’s easier to take precautions than to clean a carb out.
way2roll
Wilmington NC
Posted: 10/10/19 11:55am Link  |  Quote  |  Print  |  Notify Moderator
You should really run it monthly. The worst thing for a genset is to sit for long periods - especially gas ones.
Boon Docker
Posted: 10/10/19 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
"The worst thing for a genset is to sit for long periods - especially gas ones."
My Champion has sat for 6 months every year for the past 6 years, hasn't hurt it a bit. Maybe I'm just lucky. [emoticon]
Cobra21
minnesota
Posted: 10/11/19 06:06am Link  |  Quote  |  Print  |  Notify Moderator
I will add about 15 gallons of non-ethynol fuel to my motorhome along with 1 can of seafoam. Drive and run the genny about 15 minutes and park it for the winter. I don't start either until spring. I have done this since 2010 without issue.
Brian
Golferdude21
Illinois
Posted: 10/11/19 07:37am Link  |  Quote  |  Print  |  Notify Moderator
Ya Genny never sees a drop of ethanol, as well as every other small engine I own
hotpepperkid
Kingman AZ
Posted: 10/12/19 10:05am Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
No harm running the AC, but Gen sets should be exercised monthly not just once before storage.
I have a portable gen and it gets regular exercise. I try to but put half of the max load on it for at least 15 min. So I gather up enough things, hair dryers flood lamps ect. to give me that half load.
Some people never exercise them and than ***** because they dont run right after 6 mo of no use
2019 Ford F-350 long bed SRW 4X4 6.4 PSD Grand Designs Reflection 295RL 5th wheel
JaxDad
Greater Toronto Area
Posted: 10/12/19 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
According to Onan’s website they make about 100,000 RV type generators a year.
If you figure most of the last 20 years of production is still out there in customers rigs, that’s about 2 million units.
I recently bought some slip rings for an Onan I was given out of a derelict RV, someone had tried to ‘clean them up’ with 80 grit emory cloth. The dealer, a big factory shop, said they had to order them, they only sell a handful of them a year. Considering how few people even know about ‘exercising’ a generator let alone actually do it, this is quite amazing.
BTW, the ‘exercise once per month’ edict only appeared after Onan became Cummins Onan.
Strangely enough very few other generator mfg’s recommend this ‘exercise routine either.
