RV.Net Open Roads Forum: Tech Issues: Window Haze
 > Window Haze
Cherise66
Mississippi
Posted: 10/10/19 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Recently bought a Class A and most of the windows seem to be double paned and they have a really bad white haze..Does anyone know of a way to get it off without replacing the whole window?
garyemunson
Reno, Nevada
Posted: 10/10/19 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Do not listen to those who say they cannot be DIY fixed. You use this "Super Spacer" between the panes setting the spacer about a 1/4" from the outside of the window then fill the small gap with urathane sealing caulk. The spacer can be gotten in different widths. It is important to measure and get the correct size or the repaired window will not fit back in the frame.The worst part of the job is you have to "open up" the window frame so you can get the glass panes out. First you have to pull the window assembly from the RV. The frames are a continuous piece of aluminum bent into the window's shape and joined with a splicer. Once you get the screws out of that you can spring the frame open and get the glass out. I found, rather than totally dismantling the 2 pieces of glass, I used a razor knife to cut the old spacer out at the top and bottom leaving the window panes held together by the two sides. I did help someone whose spacer adhesive was so dried out the window pretty much fell apart once we started working on it (the new spacer has adhesive on both sides) so we had to completely re-space and seal the 2 pieces of glass. If yours seem mechanically sound, with the top and bottom pieces of spacer removed, use a rag with Turtle Wax Chrome Polish on it and use a metal coat hanger to drag it back and forth inside the two panes. You need 2 people for this. This will remove the fog. Some claim the glass is "etched" but everyone I've worked on seemed to be fogged with something like calcium buildup on bathroom faucets. The chrome polish will scrub it away. Follow up with a clean rag to get rid of the polish haze. I slid the new spacer in using a screwdriver to get it 1/4" past the edge of the glass. A little tricky as you have to pull off the protective strips from the sticky spacer material . Even if the remaining old spacers seem to be failing slightly, the two new pieces will hold the window together and the urethane caulk actually does the real job of holding the window together. Dig enough of the old sealer out on the other 2 sides to let you flow a fresh coat on and totally seal the glass. Do this on a dry day. I've never had a window refog from any trapped moisture,. The Super Spacer has some desiccant in it to lock any miniscule amount of moisture away. As for the Argon gas filling they sell in new windows, it is absolutely not necessary for your DIY repair as RVs are so poorly insulated the tiny bit of help it might give is not measurable. This job is time consuming but the savings are immense. The urethane is the real workhorse here and your repair should last 10 years as long as you make sure the glass is clean when you apply it.
* This post was last edited 10/12/19 06:41am by garyemunson *   View edit history
garyemunson
Reno, Nevada
Posted: 10/10/19 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.amazon.com/C-R-Laurence-Super-Spacer-Sealant/dp/B006JFKTUQ/ref=pd_bxgy_328_img_2/136-4484974-8224667?_encoding=UTF8&pd_rd_i=B006JFKTUQ&pd_rd_r=e6fea1f4-3f64-408f-9c4e-889f9f1cbb60&pd_rd_w=D7lPH&pd_rd_wg=6PX6V&pf_rd_p=09627863-9889-4290-b90a-5e9f86682449&pf_rd_r=8NCA19Z845E9N5WD6K2Z&psc=1&refRID=8NCA19Z845E9N5WD6K2Z
https://www.amazon.com/Black-Wide-Edgetech-Super-Spacer/dp/B00UVUUU5Y/ref=pd_bxgy_328_2/136-4484974-8224667?_encoding=UTF8&pd_rd_i=B00UVUUU5Y&pd_rd_r=bd9583a0-3a6f-4552-83b9-8720bb4ee746&pd_rd_w=SwajK&pd_rd_wg=hHaxV&pf_rd_p=09627863-9889-4290-b90a-5e9f86682449&pf_rd_r=XG0301A55FEWX9Z3JCW5&psc=1&refRID=XG0301A55FEWX9Z3JCW5
gbopp
The Keystone State
Posted: 10/10/19 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Clicky 1
Clicky 2
Excellent info, thanks for posting.
Big Katuna
Deland, FL
Posted: 10/10/19 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
It’s a common problem. I had mine fixed at Suncoast in Hudson Fl. It’s about $300 a window and they have done thousands. No leaks. The windows have to come out.
They have free hookups outside their factory.
My Kharma ran over my Dogma.
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 10/11/19 03:06am Link  |  Quote  |  Print  |  Notify Moderator
I have frameless double-pane windows that I'll be doing this repair on. Same concept, apparently.
  • 2005 Winnebago "Minnie" 31C (was a three-time Jayco owner)
  • 2012 MasterTow Dolly pulling a 2003 Jeep Liberty (had Ram 2500 CTD, Dodge Durango, Honda Odyssey...)
  • Onan Microquiet 4000, plus 130W solar and Honda EU2000i twins for backup
Scottiemom
South Dakota/Indiana
Posted: 10/11/19 05:07am Link  |  Quote  |  Print  |  Notify Moderator
We had RV Fog Doctor in Searcy, Arkansas fix ours. $200 a window. WE had to have 9 windows done. Some were etched too badly to use the same glass and required new.
Dale
Dale Pace
Wife to Terry (Teacher's Pet)
2006 Tiffin Phaeton 40'(Phaeton Place)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltiming since 2005
http://www.skoolzoutforever.blogspot.com/
Where are we?
Edd505
Elephant Butte, NM
Posted: 10/11/19 11:32pm Link  |  Quote  |  Print  |  Notify Moderator
Is the fog inside or etched glass outside? I have had luck polishing glass with a buffer and jewelers rouge.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
DancinCampers
Louisiana
Posted: 10/12/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
x2 on RV Fog Dr. Had all 6 repaired. They also have full hookups at the building.
Dan & Sharon (Kasey, Our Yorkie, RIP 9Jan'05-26Jul'17)
2012 Winnebago Journey 36M
2006 Jeep Liberty, Blue Ox Aventa II, SMI Silent Partner
If You Obey All The Rules, You Miss All The Fun
 > Window Haze
