RV.Net Open Roads Forum: Tech Issues: What good are low point drains?
 > What good are low point drains?
lenr
Indianapolis, IN
Posted: 10/11/19 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
Also, using pool noodles to insulate is a good idea, and I plan on it.
DSteiner51
Wooster, Oh
Posted: 10/12/19 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
My last 5th wheel the low point drains had a valve up inside the trailer. I never used them but they channeled cold air up to the lines so if the line froze while winter camping I knew exactly where the problem was. Solved the problem by opening up the area so interior heat could get to them.
My ‘15 5th wheel has two lines hanging down with caps on them. I don’t use them and so far... down to 14 degrees F have not been a problem. I’ve forgotten they are there until reading your post.
D. Steiner
The sooner I fall behind, the more time I have to catch up.
joebedford
Sheltering at home
Posted: 10/13/19 09:40am Link  |  Quote  |  Print  |  Notify Moderator
An interesting video on freeze damage / no damage with different types of pipe.
