RV.Net Open Roads Forum: why am I still getting this
Search only in Forum Posting Help and Support
Open Roads Forum  >  Forum Posting Help and Support
 > why am I still getting this
Bruce Brown
Northern NY
Posted: 10/12/19 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
cavie wrote:
The site has been screwed up for 4 months. lots of different errors. l Nobody cares!!!
The part about being screwed up for 4 months is true. The part about no one caring would not be accurate. Believe me, we are as frustrated as everyone else and behind the scenes Admin is doing everything possible with our limits. It is a software issue and there is only so much we can do.
It does seem to be better depending on what portal you sign in with, although that seems to move around too.
Hopefully someday soon this gets cleared up.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
1492
Arlington, VA
Posted: 10/12/19 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
I've always had both my posts and topics set at the maximum 20/40, and have not experienced the error pages. I still think the issue is on the back-end servers, so not much forum members can do on their end.
Wherever I happen to park
Posted: 10/12/19 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
It was happening on the forum group listing page (By that I mean when you first clicked on thigns like "Around the campfire" to see what's new)
Now it's either on replies or indivgule messages (lie the boycott campfires) and on that one not on the "New" only on the subject...
WOrd is they are working on it
My opnion.. they need someone who knows their bits from their bytes.
Home is where I park it.
jimh425
Western MT
Posted: 10/12/19 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
The ultimate fix is definitely on their servers, but it doesn’t mean that some of our settings don’t make it worse for some of us. Sounds like they need some testing before they roll out changes as well as at least a daily test run to find their own issues.
lenr
Indianapolis, IN
Posted: 10/12/19 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
A few years ago I had nothing but problems with RV.NET. Since switching to forums.goodsamclub.com I've had virtually no problems. It is exactly the same forum. Do it!
1968mooney
Fl.
Posted: 10/13/19 07:40am Link  |  Quote  |  Print  |  Notify Moderator
We all know the solution to the problem is charge a fee for posting. It will weed out many which will lighten the load on the server. [emoticon]
bukhrn
Lanexa, Va
Posted: 10/13/19 08:35am Link  |  Quote  |  Print  |  Notify Moderator
just went there, got exactly the same message.
2007 Forester 2941DS
2014 Ford Focus
Sam Spade
North Central Florida
Posted: 10/13/19 09:18am Link  |  Quote  |  Print  |  Notify Moderator
It seems that nobody is listening.
I'm tired of repeating the advice over and over.
P.S. And just exactly who is this "we" that is supposedly working on the problem ?? I'm not sure I buy that answer either.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
ArchHoagland
Clovis, CA, USA
Posted: 10/13/19 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Went through there and it worked good on the thread I haven't been able to access.
So there is light at the end of the tunnel.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Brian in Michigan
S.E. Mi.
Posted: 10/13/19 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
I switched over to the GoodSam portal and everything seemed to work. I searched around on a few threads and everything was fine. So I logged in and guess what the same stuff was happening. So I logged out and surprise everything started working again. I guess I'll stay
logged out.
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
