RV.Net Open Roads Forum: Truck Campers: Leaking Roof Lance TC
 > Leaking Roof Lance TC
Just Pete
Wisconsin
Posted: 10/12/19 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Has any one repaired ceiling after leak near antenna , Ceiling has wrinkled at the seam . Noticed stain in light , appears the ceiling material is starting to bubble .
jimh425
Western MT
Posted: 10/12/19 11:11am Link  |  Quote  |  Print  |  Notify Moderator
I haven’t had to do it, but I’d use eternabond and and/or dicor. I think eternabond is better for patching a small hole in the roof.
joerg68
St. Ingbert, Germany
Posted: 10/12/19 11:58am Link  |  Quote  |  Print  |  Notify Moderator
You need to fund the leak first. Do you know where the water enters? What material is your camper's roof? TPO/EPDM or aluminum?
ardvark
Bristol, TN.
Posted: 10/12/19 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Isn't the question about ceiling repair, not roof repair?
SidecarFlip
SE Michigan
Posted: 10/12/19 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Yes but, the water is getting in from somewhere, most likely the roof so you need to start with the source. Fixing the ceiling won't correct the issue.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
joerg68
ardvark, you are right.
jimh425
Western MT
Posted: 10/12/19 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
I just thought he meant roof. What ceiling bubbles?
ardvark
Bristol, TN.
Posted: 10/12/19 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
The finish on the ceiling is a ceiling board of some type. it varies by manufacturer. It bubbles when moisture gets behind it. It is much harder than a roof repair as you can see it and there is no ready match without replacing a large section.
It's important to inspect the roof regularly as by the time you see damage inside, there has been a good deal of water penetration.
Travels with Yoly
North Georgia
Posted: 10/12/19 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Water is insidious and I have seen first hand what a very small leak can do. Often the actual damage is far worse than the early signs indicate. Left undetected for even a few months it can create enough black mold to pose a health hazard and structural weakness.
This is an example of water intrusion caught before there was any signs of water damage in the interior. If you are seeing the signs indicated, there is a decent reason to do a more thorough inspection. The RV.NET photo uploader does not work on this site yet works fine for me posting on several other forums ???
[image][/img]
* This post was edited 10/13/19 10:14am by Travels with Yoly *
Just Pete
Wisconsin
Posted: 10/13/19 06:33am Link  |  Quote  |  Print  |  Notify Moderator
I found the source of the leak I was a roofer for 23 years specializing in flat roofs , My question is has any body repaired the ceiling panel , Thinking of trying to inject some typ of glue in the bubbled area , The damage is at the seam where 2 panels meet there seams to be a joining strip or clip
