Just Pete
Wisconsin
Has any one repaired ceiling after leak near antenna , Ceiling has wrinkled at the seam . Noticed stain in light , appears the ceiling material is starting to bubble .
jimh425
Western MT
I haven’t had to do it, but I’d use eternabond and and/or dicor. I think eternabond is better for patching a small hole in the roof.
joerg68
St. Ingbert, Germany
You need to fund the leak first. Do you know where the water enters? What material is your camper's roof? TPO/EPDM or aluminum?
ardvark
Bristol, TN.
Isn't the question about ceiling repair, not roof repair?
SidecarFlip
SE Michigan
ardvark wrote: Isn't the question about ceiling repair, not roof repair?
Yes but, the water is getting in from somewhere, most likely the roof so you need to start with the source. Fixing the ceiling won't correct the issue.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
joerg68
ardvark, you are right.
jimh425
Western MT
I just thought he meant roof. What ceiling bubbles?
ardvark
Bristol, TN.
The finish on the ceiling is a ceiling board of some type. it varies by manufacturer. It bubbles when moisture gets behind it. It is much harder than a roof repair as you can see it and there is no ready match without replacing a large section.
It's important to inspect the roof regularly as by the time you see damage inside, there has been a good deal of water penetration.
Travels with Yoly
North Georgia
Water is insidious and I have seen first hand what a very small leak can do. Often the actual damage is far worse than the early signs indicate. Left undetected for even a few months it can create enough black mold to pose a health hazard and structural weakness.
This is an example of water intrusion caught before there was any signs of water damage in the interior. If you are seeing the signs indicated, there is a decent reason to do a more thorough inspection. The RV.NET photo uploader does not work on this site yet works fine for me posting on several other forums ???
[/img]
edited 10/13/19 10:14am by Travels with Yoly *
Just Pete
Wisconsin
I found the source of the leak I was a roofer for 23 years specializing in flat roofs , My question is has any body repaired the ceiling panel , Thinking of trying to inject some typ of glue in the bubbled area , The damage is at the seam where 2 panels meet there seams to be a joining strip or clip
