RV.Net Open Roads Forum: Tow Vehicles: Tow with Chevy Bolt?
Search only in Tow Vehicles
 > Tow with Chevy Bolt?
camperfern
Rochester
Posted: 10/12/19 10:33pm Link  |  Quote  |  Print  |  Notify Moderator
Hey, Folks. I'm thinking about leasing or buying a Chevy Bolt. Officially there is no tow capacity though I understand I can have a Class 1 hitch installed and tow up to 2000 lbs. I'm considering buying something like a T@B/Little Guy trailer. I'm wondering if anyone tows with a Bolt? Also wondering how much it impacts the battery range? Thanks in advance for any feedback.
camperfern
pianotuna
Regina, SK, Canada
Posted: 10/12/19 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
Range may be quite adversely affected.
Regards, Don
time2roll
Posted: 10/13/19 12:06am Link  |  Quote  |  Print  |  Notify Moderator
I have been driving electric since 2011 but never towing with it. I would expect range to be cut in half. Need L3 charging every 100 miles and could be awkward with a trailer. I wish I could recommend something else but the only option is Tesla for a bit more $$$$. I would expect more options available in 2 to 5 years.
675w Solar pictures back up
gbopp
The Keystone State
Posted: 10/13/19 04:51am Link  |  Quote  |  Print  |  Notify Moderator
Installing a hitch on a leased vehicle doesn't sound like a good idea to me.
Maybe this forum can help answer your questions?
Chevy Bolt Forum
carringb
Corvallis, OR
Posted: 10/13/19 06:33am Link  |  Quote  |  Print  |  Notify Moderator
X2 - Don't do if you are leasing. Check the actual contract terms of the lease, but there's probably some verbiage to allowing them to penalize you at turn-in, for modifying it or using it beyond the factory ratings.
If you buy it, do what you want. Hitch receivers are available for up to to 200 pounds tongue weight, 2000 pounds towing. Pulling a camper trailer on the highway will result in miserable range however. You'd be fine towing a cargo trailer in town, but pulling a larger trailer on the highway, all of your power is going to moving air. You'll probably on have 1/3 the range of normal. Tab trailers look like they should pull easily, but most folks see zero fuel economy improvement over their former box-shaped trailers, possibly because the the air-gap between the trailer and tow vehicle is longer.
Also, anything larger than a small popup will have more than 200 pounds rongue weight.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
Bumpyroad
Virginia
Chevy Bolt Forum
probably against the "rules". especially on such a "puny" vehicle.
bumpy
eHoefler
ozark mountains
Posted: 10/13/19 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Also will void the warranty
2019 Ram Limited, 3500, Crew Cab, 1000FTPD of Torgue!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
trail-explorer
NM
Posted: 10/13/19 07:14am Link  |  Quote  |  Print  |  Notify Moderator
The Bolt is not intended to tow.
Using an EV as a tow vehicle sounds like a huge burden.
Bob
colliehauler
Mc Pherson KS USA
Posted: 10/13/19 07:37am Link  |  Quote  |  Print  |  Notify Moderator
Have you ever heard the expression "use the right tool for the job" a Chevy Bolt isn't it. A whole new line of electric pickups is set to hit the market that might meet your needs.
camperfern
Rochester
Posted: 10/13/19 07:41am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for taking time to respond folks. Yes, I'm aware of rules and controversies, etc. What I am looking for is any actual experience and/or Bolt owner(s) who have thought through this. :-)
