RV.Net Open Roads Forum: Truck Campers: Seized valve cable
 > Seized valve cable
Faststreak
Mississippi
Posted: 10/15/19 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
At this time cable is still seized. Waiting for Cable life lubericant to arrive.
ChadHubbard
Seymour, IN
Posted: 10/16/19 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
If you can remove the handle from the cable, I have had success with this: purchase some clear plastic tubing (18") that will slice tightly over the end of the cable sheathing, or screw over the threads if there are threads. Tighten with a cable clamp. Wire tie the cable in a vertical position. Fill the tube with a light oil. Give it a couple of days. The oil should wick down between the cable and the sheath. If you can get the cable to move, work it back and forth carefully. It will be lubed for a long time.
Chad Hubbard
2014 Ram 3500 SRW 2x2 Cummins Aisin
2003 Fleetwood Pride 31-5G
ticki2
NH
Posted: 10/16/19 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
A 50/50 mix of ATF and acetone makes an excellent penetrating oil . Remember to hook up your slinky hose before trying the cable . [emoticon]
'68 Avion C-11
'02 GMC DRW D/A flatbed
BobsYourUncle
Calgary Alberta Canada
Posted: 10/16/19 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Deleted
Dmax/Allison
1997 Triple E Topaz 27' Bunkhouse TT
I do
Precision Guesswork
based on
Vague Assumptions
Unreliable Data of Dubious Accuracy
provided by persons of
Questionable Intellectual Capacity
Now, What would you like done?
RobG
Mesa, AZ
Posted: 10/17/19 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I'm having a similar problem with the black valve on my 5th wheel... BUT... the trailer is 13 years old and so is the valve. And I've lived in it fulltime for 12 of those 13 years. This started earlier this year and is getting worse. I can still get it open but it's very difficult and I'm worried about breaking it.
I've torn into the underside of the trailer, and I can replace it, but just have to get around to DOING that. Until then, I love the ideas posted here about lubing the cable. I'm going to try those.
2019 Arctic Fox 992 Truck Camper
2006 Keystone Raptor 3814SS 5th Wheel Toyhauler (live in it fulltime)
2005 Dodge RAM 3500 Quad Cab Dually 4x4 SLT 6sp
A quad, a few motorcycles, and a dog.
Faststreak
Mississippi
Posted: 10/17/19 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
The cable runs tthrough a metal sheath to mount it to the frame of the box. How will I get lube down the cable as the metal sheath runs most of the length of the cable. Mr Phelps how did you get lube inside to the cable?
